Madman's Alternator Bracket
Old Feb 5, 2003 | 12:59 PM
1BAD-SS's Avatar
I ordered this kit. It should be made of gold for $175. The belt they sent me with the kit is for a 2.3 ford, but it is too long. Can anyone let me know if they had any troubles with this. I cannot get in touch with Madman Racing.
Please help.
Thanks,
Craig
Old Feb 5, 2003 | 03:24 PM
Brady's Avatar
the belt I got was too long, I bought a shorter one at the auto parts store. no biggy.
Old Feb 5, 2003 | 05:06 PM
chevyguy3's Avatar
hmm, the belt that came with my Madman bracket was a little too short. i just elongated the slot in the bracket a little so i could move the alternator in closer to make it fit instead of buying another belt
Old Feb 5, 2003 | 05:10 PM
madman69's Avatar
I havent had any phone calls on this subject. Our kits are sold with a stock balancer. There are 2 belt sizes a 36 for a stock balancer and a 34.5 for a aftermarket balancer. OR if you have an underdrive pulleys then you need a shorter belt.
Old Feb 6, 2003 | 06:48 AM
1BAD-SS's Avatar
Well, I changed back to my original ballancer when I put the bracket on and the belt is too long. If I elongate the hole, I will cut through the end of the bracket. I need a shorter belt.
Thanks,
Craig
Old Feb 6, 2003 | 06:58 AM
madman69's Avatar
Call me at the shop and I will get you what you need. 281-449-8833
Old Feb 6, 2003 | 09:55 AM
yellow Z28's Avatar
I got one a few months back...Bolted right up no problems..im using a ATI Balencer...dont know if that matters or not...belt worked fine!
Old Feb 6, 2003 | 12:20 PM
1BAD-SS's Avatar
Will do.
Thanks,
Craig
Old Feb 11, 2003 | 07:06 PM
1BAD-SS's Avatar
I bought the 34.5 inch belt that you recommended. It is too short.
36" is too long.
34.5" is too short.
I shouldn't have to chase down a belt for this. I must have the wrong bracket. If I try to use the 36" belt, I run out of bracket. The alternator hits the block before the 34.5" belt will work, but the bracket shows plenty of adjustment that way.
I ordered it, took 2 weeks to get it, tried to get help to fix it, could not reach you, and now it still doesn't work.
Thanks,
Craig
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
War Engine
Sep 18, 2015 07:28 PM
