Trying to load PCMfor less;cable error ect. need help
Old Feb 3, 2003 | 10:13 PM
95 Mystic TA's Avatar
Well I got through the other problem with the boot disk but ran into another. Once I got the program opened, and the cable plugged in, the message opened that said :
"attempting to communicate" and then said "cable error" I am trying to use two cables. When I got the 15"ft cable it turned out to be too small so I bought one at ComUSA (local pc store) and the connections and everything hooked up and everything sound. What could be the problem? Obviously the cable but how? I bought the cable through AEKM I think it was, the company that most of you guys buy yours from. Anyone shed some light on this? Thanks in advance.
BTW: This is a repost from LT1 Tech in case they can't help.
Old Feb 4, 2003 | 11:21 AM
c5formetoo's Avatar
check your comport setting
Old Feb 4, 2003 | 04:53 PM
mtxpert's Avatar
You probably bought the more expensive straight through cable thinking it was better. You need a standard male to female 9 pin extension cable.
Mike
Old Feb 4, 2003 | 08:53 PM
Dr.Mudge's Avatar
Too small? Count the pins that you need, there are only 2 cable types on the back of the computer other than male/female versions of the same pinout, serial and parallel.
Old Feb 5, 2003 | 03:48 PM
mtxpert's Avatar
I think he was referring to length. It sounds like he's using a desktop to do his upload/download.
The problem with serial cable extensions is that they do offer either the straight through or standard. If you get the wrong one you will mix signals at the connector.
Mike
Old Feb 7, 2003 | 02:01 PM
Thumbs up
Thanks guys for your responses. I posted this in LT1 tech and found the problem and forgot to check this section. I am running it from my desktop. I found I was using the wrong port. I swapped with my printer and that did it. Thanks again.
Novo
Jun 14, 2016 02:58 AM
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
marlar98
Sep 19, 2015 07:53 AM
