Cai?
Old Aug 25, 2010 | 03:54 PM
gomezcorp's Avatar
Cai?
So of all that have replaced the stock air induction system with a new CAI, what is considered in your opinions to be the best CAI? RC2, Hennesey etc...
Old Aug 25, 2010 | 07:36 PM
Highlander's Avatar
BOth that I have installed and tuned, both gave 0 without the tune.. after the tune..both gave 7whp.
One of them is the ADM Performance.
If you install a CAI and interested in a tune let me know.
Old Aug 26, 2010 | 06:55 AM
2010_5thgen's Avatar
i did airaid. it was cheap and a nice kit. when buying a cold air intake, the straiter the flow the better. the colder the air the better.
Old Aug 26, 2010 | 05:17 PM
JasonD's Avatar
Admin Emeritus
Pick the one that has the best quality filter, looks good, and is the price you want. That method of selection will provide more enjoyment than pulling your hair out to find which one has 1/10 of a HP increase in a +/- 2% throttle window at a cost of $100 more.
In fact, I would simply ignore HP numbers completely. That can be calculated a number of different ways and some are hilariously high.
Old Aug 27, 2010 | 06:44 AM
an intake is an intake. their all good for around the same exact numbers. and trust me, your not going to notice if one gets 1-3 hp better than the one thats $100 less.
Old Aug 31, 2010 | 12:14 AM
gomezcorp's Avatar
So what is all involved with a "Tune?" Thanks 4 your input.
Old Aug 31, 2010 | 12:17 AM
gomezcorp's Avatar
So does it really make a difference whether you install a metal tube versus a poly/rubber tube on a CAI? Is there a real HP/performance difference that's noticeable? Thanks
Old Aug 31, 2010 | 06:45 AM
only difference really might be that the plastic tube removes heat from itself quicker than a metal tube.
as far as what involved in a tune, you wont need one done for just the intake. it would be a waste of money ifyou plan on doing more upgrades. they go into the computer of the car and change things. depends on what is done to the car.
Old Aug 31, 2010 | 04:02 PM
SSCamaro99_3's Avatar
If I am thinking about thermal conductivity correctly the metal tube should pick up heat faster, and shed it faster than a plastic tube with lower conductivity. This should especially be true in a thin wall/ high surface application such a a CAI.
Old Sep 1, 2010 | 07:02 AM
the metal will also pick up heat from the motor from the outside. i think this is why most aftermarket intakes are plastic. that and injection molding is cheaper.
Old Sep 1, 2010 | 07:16 AM
razor02097's Avatar
Yeah I'll admit it.
I chose moroso because it was cheaper then the others. The kit installed fine and actually weighs half a pound (8oz) less then the stock system with the 2 fender baffles.
Old Nov 13, 2010 | 05:31 PM
67 LS-1 & T-56's Avatar
Re: Cai?
I just picked up a Roto-fab. Fit and finish is nice, I swear the butt dyno tells me that it was a good choice.
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
surreybrad
Aug 10, 2015 09:34 AM
