Ported TB
Old Feb 3, 2003 | 01:33 PM
darkoverlift's Avatar
Buddy messed up TB after finding out how to port online
goal10dr got off the internet how to port the 3.8 tb. So we did it. It was a lot like porting the maf on my LT1. The only difference is he occasional throws a code and his car runs like crap. It does idle under 900 but it just sounds weird... He has a 1996 3.8 in a bird... Any ideas? A mod that was susposed to gain him 10HP has cost him 20 I bet...
Old Feb 3, 2003 | 05:28 PM
Would it be possible for him to buy a 70MM TB somewhere or some larger TB?
Old Feb 3, 2003 | 09:01 PM
Well the ses light won't go off and it seems like his 3.8 just can't breather or is runin lean.... Anyone???
Old Feb 3, 2003 | 10:39 PM
ttt
Old Feb 4, 2003 | 06:43 PM
Autozone told him his codes are a lean left and right bank.... Any ideas?
Old Feb 5, 2003 | 01:29 PM
DEE97GTP's Avatar
I don't know what instructions you followed, but you probably screwed up how the MAF reads. You probably cut out half the post. If you did, the MAF won't read right. I would see if you could find a 99+ MAF sensor, cutout the rest of the most and use it.
DEE
Old Feb 6, 2003 | 06:20 AM
He called autozone and they told him a 99 and newer does not use a MAF... He said they use a MAP sensor and are speed density...
Old Feb 6, 2003 | 08:24 AM
DEE97GTP's Avatar
What? That is total BS. You won't be able to buy that sensor from autozone anyway. You'll have to go to a salvage yard or the dealer.
DEE
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
