NOS KIT...plugs and pills???
Old Feb 2, 2003 | 10:59 PM
amc91z's Avatar
I'm putting an NOS wet kit on my 91 z28. Its a 383 sroker with 10:1 comp and other mods in sig. I've got AC R45TS plugs in it...what do you guys think would work the best with what I've got. I'm also trying to find out what pills will make 100 hp and what makes 150...thanks for any help.
Adam
Old Feb 5, 2003 | 07:49 PM
amc91z's Avatar
anyone???
Old Feb 7, 2003 | 01:10 PM
onefastgta's Avatar
100 for the TPI kit is 55-42
150 is 70-53
both at 40 psi fuel pressure. The 45's are the stock heat range, might want to go down to 43 or 42. Don't count out the autolite plugs at wal-mart either, I think they are autolite 103 and 104, but you'd have to double check.
Old Feb 9, 2003 | 06:27 PM
stik6shift00's Avatar
Old Feb 9, 2003 | 06:55 PM
amc91z's Avatar
why the
Old Feb 9, 2003 | 07:49 PM
are you saying you use pills to adjust the shot...i thought it was on the solioid?
Old Feb 9, 2003 | 08:52 PM
amc91z's Avatar
Dude, you lost me...lmao! The pills go in the plate between the throttle body and the plenum as far as I know...
Old Feb 9, 2003 | 11:01 PM
stik6shift98's Avatar
by pills do u mean jets.....
Old Feb 10, 2003 | 10:12 AM
onefastgta's Avatar
Pills=jets. On the NOS TPI kit you adjust the fuel and nitrous jetting using jets that go into the side of the throttle body plate. This is a wet kit, not dry.
Old Feb 10, 2003 | 12:52 PM
ttt i still dont get the pill thing??
Old Feb 10, 2003 | 04:52 PM
RacinLT1's Avatar
whats not to get about "pills"? it's slang for jets.
All nitrous kits use jets/pills to control nitrous/fuel flow,and all the jets go at the nozzle and or plate.
Nothing too confusing
Old Feb 10, 2003 | 05:53 PM
thats what i thought
plugs=pills
Old Feb 12, 2003 | 08:16 PM
amc91z's Avatar
Also, what should I set the timing at????
Thanks,
Adam
Old Feb 12, 2003 | 08:18 PM
i think its -2
Mar 13, 2016 03:39 PM
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
cardemo16
Aug 24, 2015 01:04 AM
colts0455
Jul 20, 2015 09:52 AM
