Abs Unit
Old Feb 2, 2003 | 09:38 PM
DirtyredT/A's Avatar
Question Abs Unit
Anybody know how to eliminate the ABS unit from the engine
compartment? Are there any different things (parts) that are
needed to take place of abs unit
Any help
Old Feb 12, 2003 | 12:00 PM
Hot Rod Hawk's Avatar
Smile
http://www.trzmotorsports.com
under new products, master cylinder adapter
Old Feb 12, 2003 | 12:58 PM
dreamer1q's Avatar
I have heard that you can just run what you already have as long as you use a "T" spliter. Never heard of this one You have any info Hawk?
Q
Old Feb 12, 2003 | 04:32 PM
Dreamer...
The ABS unit has the brakeing systems "Proportioning valve" built into that. Removing the abs unit = no brakeing bias other than what the factory gm master cylinder has.
If one was to run the factory Vacuum\master cylinder without the abs unit you would need to add a "Adjustable Proportoning valve" to the system to control or keep from having too much front braking vers the rear...."Brake bias"
A "Tee" would be needed to split the Front side of the master cylinder circuit output into two lines....one for each caliper.
The rear output runs back and is "Tee'd" above the axle and runs to each caliper.
Stainless Steel Brakes has the "PValves" and if running a line lock I'd get the proportioning valve with the guage. That way you can run a line off it an monitor the brake pressure from inside the car when pumping up the system with a line lock on. Knowing your "Holding Pressure" is a must or you will creep in the lights and get a big red eye!
ttyl
Old Feb 12, 2003 | 06:11 PM
dreamer1q's Avatar
I follow ya...I have already removed the ABS unit, and was considering the adjustable valve. Now I know I will go with it. Just have to figure out where I want to mount it, in cab or under hood.. In cab would be kinda trick
Old Feb 15, 2003 | 04:25 PM
Thumbs up
Thanks Hawk. Its been a while since we've talk about this
elimination. Motors out and compartment will be sprayed with fresh coat of paint. If I went the adapter route will I need
to buy the Pvalve also?
Old Feb 18, 2003 | 12:08 PM
This adpter allows you to remove the vaccum assist unit and the factory master cylinder assembly.
You will have to run a mopar master cylinder that has the pvalve built into it if you use this adpt plate. That master cylinder is low dollar.
Lookie what Brady did if your gonna just ditch the abs>>
http://www.turbocharged.net/ABS/
Thanks Brady
Old Feb 18, 2003 | 04:26 PM
Cool
Thanks Hawk. I've been trying to find bradys site.
?Is that a line loc nearest firewall coming off master cylinder?
If so I do not need one with a transbrake. Must have Pvalve
though. Rerun some brake line no prob...
Old Feb 18, 2003 | 04:31 PM
Must have Pvalve
YES< YES>and YES
Old Feb 18, 2003 | 04:47 PM
Cool
Thank ya Thank ya
Old Feb 18, 2003 | 11:24 PM
AL SS590 M6's Avatar
Wouldn't you still need a line lock to properly warm up the slicks?
Old Feb 19, 2003 | 08:03 AM
Al your correct, I would still use one just for that reason. Why over heat the rear brakes any more than needed and it also would keep you from loading the Converter and throwing anymore heat into that as well. A trans brake will be hard enough on that bad boy.
Old Feb 19, 2003 | 08:01 PM
Yes, this is why I will also purchase a line loc.
Thanks for clearing that up for me fellas.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
