Alignment needed after shock install ?
I didn't get my car aligned after I installed Bilsteins-and it drove just the same. However, there was a note included in the boxes that said to get the car re-aligned after putting on the shocks.
The time that you'd do an alignment after installing shocks is if the new ones are gas pressure, particularly if they're high-pressure units (Bilsteins, KYB Gas-A-Justs, etc.). The assumption goes that the old ones were non-gas pressure, low-pressure gas, or that the gas has leaked out, hence your new ride height would increase slightly with the new ones. It's this ride height change that warrants at least a check on your alignment settings.
Norm
Norm
Hurin
Dec 13, 2014 07:38 PM
