Best things to get if Rebuild?
Old Jan 31, 2003 | 03:54 PM
foshizl's Avatar
I was wondering what are the best things to do to your engine if you wre going to rebuild it? like what components new cam shaft etc.
Old Feb 1, 2003 | 03:46 PM
Sephiroth's Avatar
Get a crate 5.7...........dont wast money on the 3.8, or in worst case 3.4.
Old Feb 1, 2003 | 04:23 PM
MustangEater82's Avatar
woohooo troll of the week.
and how much does a crate lt1 or ls1 cost?
now compare that to what the guy wants, a rebuild with maybe some gains.
You do know not everyone is trying to make a 9 second car some peopel just want a little pep out of their daily driver.
Alright now can you tell us what you drive so we can pick apart about how stupid you re for waht you did becasue you obvioulsy are an idiot.
Old Feb 1, 2003 | 05:29 PM
Sephiroth's Avatar
Ok big boy, i can get a 5.7 300hp ( i know, its low ) for 3k. Go ahead and re-build a 3.8 or 3.4 for 3k. Yea, i dont know anything, just a troll. BTW i drive a 93z, 03GT, 71Malibu, try again noob, just IMO.
And puting a crate in a v6Fbod hardly means running 9's.........go watch the F&F again big guy
Old Feb 1, 2003 | 10:03 PM
2turboz28's Avatar
i am building a 400hp 3.4L for around 3500$. and its alot more than 3k to do an lt1 swap. all of those little sensons and fitings do add up to some money. dont even try to do an ls1 swap without at least 6k. do some research before you shoot down someones dream of a fast six!
btw, thats a whole intercooled turbo kit, not n/a! i could get 300hp from a 3.4L or under 3k!!!!
Old Feb 2, 2003 | 05:59 AM
bunker's Avatar
Old Feb 2, 2003 | 01:10 PM
Why are you wasting your time on a LT1? The LS1 is where its at, same with only a 03 GT, a 03 Cobra is already built fromt hte factory, and didn't some guy get around 700 hp with bolt ons only with sticl supercharger, and and stock motor?
Yup are wasting yout time, you will have to spend alot of money on bolt ons jsut to get your lt1 to even just be a match for a LS1, and don't even get me started on what you will need ot do on your GT.
And I hope you are talking about a crate LT1 or crate LS1, because a regular crate small block with a distributor, will be very hard to fit under the cowl, and once you do get it ot fit it will be very hard to work on, hence why the Lt1 and Ls1 do not have a distributor in the back of the motor like a regular small block.
And ok $3000, for a 350
Now you need to buy a new driveshaft, rear end, crossmember, ecm, harness, front springs, all acceories, transmission. Thats just off the top of my head, I don't know the everything.
So lets just say you are having buttsex with your local junkyard owner and get a all that for $1,000 which is pretty much impossible.
so $4,000 for that whole car, so this is betterh then a $900-$1500 rebuild the guy was looking for. And he will have a motor made for his car instead of a motor swap and a freshly rebuilt motor.
Not sure you plan works to well.
Old Feb 2, 2003 | 01:18 PM
btw what I meant by the 9 second comment is the fact that not everyone can afford or wants a built car that fast. If they did don't you think everyone would be drivng 250hp+ cars and the f-body wouldn't have been discontinued?
Old Feb 3, 2003 | 01:13 AM
TTT for the original question..
I do not know too much, but I am sure Grand Prix GTP internals are swappable with a 3.8L in f-bodies, that might be a relatively cheapre route to have a motor that can handle boost with out spending too much money.
Assuming you ever want to go super or turbocharged.
Old Feb 3, 2003 | 10:29 AM
foshizl's Avatar
once again no one really answered my question
Old Feb 3, 2003 | 10:43 AM
2turboz28's Avatar
get a cam, port the heads and intake, get high compression pistons, and thats about it. the rest you should do is all external engine stuff like headers and ignition stuff!!!!!if you need parts then e-mail me
Old Feb 3, 2003 | 02:49 PM
blue95's Avatar
it depends on how far you are wanting to go with your rebuild and what you are willingly to put into the car and what you want after the rebuild.
Cam and headwork would be the main things....high compression pistons are a bit much unless you really are doing some serious engine work...but not a bad idea...
Sergio
Jan 27, 2016 04:27 PM
alex5366
Mar 27, 2015 03:30 PM
armedtrigger
Feb 24, 2015 08:30 PM
Hal Fisher
Sep 14, 2002 09:36 PM
