questions about tuning on a bolt on car?
Old Jan 31, 2003 | 03:15 AM
JCSWS6's Avatar
I was talking to a guy the other night and he told me he picked up .3 in quarter just by getting custom tuning done. He had a 02 ws6 with almost the same mods as me. Do any of you have knowledge on this? I can get it done for under 200 but I want to make sure I will really see a improvement. I didn't think a mostly stock car would benifit much?
Old Jan 31, 2003 | 07:39 AM
ShaneS's Avatar
With the mods you've got listed, it is possible that you are running pretty lean, and *may* benefit from tuning. I, too, have a bolt-on car, and picked up ~10hp/10tq from simple dyno tuning using LS1Edit. If you plan on doing a lot of mods to your car, LS1Edit is a good investment. Otherwise, I think you'd spend almost the same amount (~400-500$) just to get a single shop tune done...
good luck,
Shane
Old Jan 31, 2003 | 08:33 AM
PhantomTA's Avatar
then again you may be running really rich..
you have no way of knowing for sure how much your car will pick up..
some cars repsond better based off who knows what... you wont know till you get it done for sure.
Old Jan 31, 2003 | 09:11 AM
ShaneS's Avatar
True, true... So the answer is: it depends.
Shane
Old Jan 31, 2003 | 10:57 AM
My84Z's Avatar
dyno your car and get a a/f reading then go from there if it is rich or lean yes you will benefit if it is ok then no you won't.
Old Jan 31, 2003 | 12:10 PM
rncotton's Avatar
Or if you have a little black smoke out the pipes at WOT, then you know you're running rich and could use a tuning.
I need to get LS1 Edit and tune my ride.
97SSdude
Dec 31, 2014 07:43 PM
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
