rims
Old Jan 29, 2003 | 04:26 PM
2000camaroRS's Avatar
rims
i need help putting on my new SS wheels....wut does it do to the speedometer exactly and wut do i hafta do to fix it...i heard it doesn't read the speed correctly...help me out
Old Jan 29, 2003 | 11:07 PM
Notorious_mgm's Avatar
Your speedometer will read slower than you're traveling which won't hurt anything except getting pulled over and actualy not know you were going that fast. It also might through off the ABS. A HPP3 will fix this problem
Old Jan 29, 2003 | 11:28 PM
wut is an HPP3? and wut does it do to fix the problem?
Old Jan 30, 2003 | 12:52 PM
chesee48's Avatar
"WHAT" a Hypertech Power Programmer does is recalibrate your tire size for the speedo and for when u change gears..it also allows you to turn on the fans earlier and change the shift points..
a piece of junk except when u need to change the speedo for the gears/tire size
Old Jan 30, 2003 | 03:12 PM
how do i go about gettin an HPP3? and once i have it do i have to program it mself or is it automatically done once installed?
Old Jan 30, 2003 | 03:54 PM
99blackSS's Avatar
It shouldn't affect the speedo because the wheels are bigger but the tires are a lower profile.
Old Jan 31, 2003 | 05:22 AM
1fastV6's Avatar
the hpp3 is 300+ bones. and its easy to use once you get it.
and i do believe changing wheel size affects the speedo.
Old Jan 31, 2003 | 07:30 AM
95GRNZ's Avatar
The overall diameter is the key. If he is putting on 17" SS wheels, the overall diameter will be larger, thus throwing off the speedometer.
Probably not by much, but still.
TS
Old Feb 1, 2003 | 02:09 AM
SixVi6-Camaro's Avatar
I'd forget the power programer.. you would have to put 40" swampers on the car to really make a noticable difference in the spedo. why throw away 300+ for the programer just to get a 1-2 mph fix?
Old Feb 1, 2003 | 11:18 PM
SageofKnight's Avatar
Shouldn't effect your speedo at all if you get the right tires for the rim.
Work it out like this for your stock tires now....
((Tirewidth * AspectRatio)/25.4)*2 + RIM diameter
Compare it to SS Wheels and Tires
((275 * 0.40)/25.4)*2 + 17= 25.66 overall diameter
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
