intercooler piping
Old Jan 28, 2003 | 10:32 PM
tbehling's Avatar
intercooler piping
what size piping would you reccomend for the intercooler piping a an lt1 turbo set up? would standard aluminum exhaust pipe work? give me some ideas here boys
Old Jan 28, 2003 | 11:00 PM
zturbo's Avatar
How big of turbo or turbos, level of boost? How much hp are you wanting total? Alum tubing is fine (are you meaning aluminized tubing? The only prob with it is i would think it would rust eventually.
steven
Old Jan 28, 2003 | 11:14 PM
tbehling's Avatar
i am going to run about 8lbs of boost off of a t04 hyrbrid. I am going to paint the pipes so i dont think the rust will be an issue
Old Jan 29, 2003 | 01:00 PM
texlurch's Avatar
I used aluminized exhaust tubing. If you could find aluminum pipe and bends, and IF you could weld it, that would be the way to go. A lot lighter.
Sizing .. I sized mine to match the inlet/outlets of the turbos, and intercoolers.. keep in mind the TB on an LT1 is around 4", so you will have to get it to that size at the end.
You can paint the outside, what about the inside? There will be some condensation.. I plan to get mine ceramic coated when the ol' pocketbook allows! Inside and out. A side benefit will be to keep the engine heat away..
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
