Adjustable fuel pressure regulator?
Old Jan 22, 2003 | 05:31 PM
BottleFed94Z's Avatar
Guys, I just dropped in a new motor with LT4 hot cam roller rockers exc...and I'm using Accel 30# injectors and have added custom PCM tuning and an inline ATI fuel pump. The problem is that I think the car in running lean. I pulled the plugs this weekend and most of them were white. The car seems to run real good when its cold but starts running sluggish when it reaches normal operating temp. I'm sure this is because its in close loop when its cold therfore running richer, then leaning out when the car goes into open loop. Has anyone had this problem? should I be using an adjustable fuel pressure regulator to bring up the fuel pressure? If so, what should I set it at ?
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
F(ast)-body
Feb 26, 2003 09:05 AM
dansam
Jul 20, 2002 01:10 PM
