Advice needed on oil pan removal
Old Nov 18, 2009 | 06:44 PM
'97SS's Avatar
After doing a ton of searching, I have not found the answer so...
On my '97 ss there are coolant lines on the drivers side. I assume these are for the oil cooler. Someone correct me if I am wrong please. How do I get under these to get at the bolts? Do they need to be removed?
Thanks in advance for any help.
Old Nov 18, 2009 | 08:42 PM
andysc's Avatar
You should just remove the oil cooler anyway. There have been numerous posts about it, how to remove it, and the benefits. I did it, and my oil pressure went up a couple of pounds. But yes getting it out of the way will make it easier to remove the oil pan. I did not see if you were a M6 or A4, it is said to be easier for the A4 folks, I have a M6. Still can be done, just more involved. Again lots of posts on how to do it. I am putting it off, but untill I get a serious leak or problem, I don't have the time to do mine know. If you do remove the pan, I suggest changing the timing chain set , and replacing the gaskets in the timing cover.
hth
andy schuck
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
mjcent922
Jul 27, 2002 12:42 PM
