95 pcm and 95 lt1 in a 97 z28
Old Nov 18, 2009 | 02:19 PM
diamondhill's Avatar
what is necessary for this swap.. .... i bought a 97 roller, and already had a 95 pcm and 95 engine with ported heads and bigger cam... i cant get it to run .. can some one point me in the right direction
Old Nov 18, 2009 | 02:33 PM
bw_hunter's Avatar
I think it might be the VATS. Take a look at SHoebox's page for details...
Old Nov 18, 2009 | 03:16 PM
meissen's Avatar
Are you using the 95 engine wiring harness or the 1997 engine wiring harness? You're going to be dealing with some fun stuff because 1995 is OBD1 and the vehicle is OBD2. You'll need to go to shbox.com and compare all the connector harnesses. I only looked at C100, C105, and C210 and in 1995 to 1996-1997 they changed where the PCM gets it's power from:
http://shbox.com/1/harness_connector_faces.htm
C100 - Cavity "D" 1995 is the Power feed from PCM fuse #8 to PCM, 1996-1997 it's not used
C210 - Cavity "C" 1995 is 'info not known', 1997-1997 it's Power Feed from PCM Bat Fuse to PCM
Old Nov 18, 2009 | 03:24 PM
im using 95 pcm and harness.. i do have access to a 97 pcm and harness would that make things easier.. and also the engine i have installed is not equiped with a crank or cam sensor
Old Nov 18, 2009 | 03:27 PM
bw_hunter's Avatar
It doesn't need a crank sensor to run and the opti is the cam sensor. Since you're using the engine 95 setup, the problem isn't a mismatch there. What do you have....does the engine turn over? Is there spark? Can you hear the fuel pump run and does it have fuel pressure?
Old Nov 18, 2009 | 03:34 PM
it cranks, but no spark or fuel ... tho i think the fuel pump may be dead its been sitting for a long long time
Old Nov 18, 2009 | 03:36 PM
no injector pulse or spark
Old Nov 18, 2009 | 04:05 PM
94ZRagtop's Avatar
You sure your injectors are good? I've seen it multiple times with engines that sit for a while, the injectors varnish over and get clogged and don't fire. Put 12V across the injector and see if you hear it 'tick'. No tick = clogged injector.
Another point of failure is the opti harness connector. Make sure it's nice and clean, and not corroded or broken.
Old Nov 18, 2009 | 04:43 PM
there new accel injectors..
Old Nov 18, 2009 | 04:46 PM
im not getting any power to the injectors no voltage at the injector plugs??????
Old Nov 18, 2009 | 07:13 PM
meissen's Avatar
Check the injector fuses just to be sure. But I really think you're going to have to trace the wires going to the injector fuses through C100 plug on the passenger shock tower. It's more than likely a wiring issue. When I did my engine swap from a 94 v6 to a 95 v8 I had to splice in the wiring for the injectors.
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
thenewkid
Nov 27, 2014 09:41 AM
