Super Vic and 4150 TB?
Old Nov 15, 2009 | 04:14 PM
jay_rich's Avatar
Okay, Im looking into converting to a Super VIC possibly going to reg distributor also.
Which super vic do I use?
Summit has a Super vic for Vortech heads already with Injector bungs. Will this fit on the heads (as in flat and ports line up)
http://www.summitracing.com/parts/EDL-29135/
I know I need to convert the bolt holes still.
Also im looking into a 4150 style Throttle body.
Now I am forced induction prob be tossing 15-20PSI thru my 383 Single turbo.
This is a street/strip car. Would I be fine with the 1,550 CFM or would it be really laggy not in boost?
Here are the accel ones.
ACC-74202S2 .....1550cfm
ACC-74202S3 .....1350cfm
ACC-74202S4 .....1200cfm
Shooting for 750-800RWHP on pump gas
Jay
Old Nov 18, 2009 | 01:52 PM
jay_rich's Avatar
no-body has a clue?
Jay
Old Nov 18, 2009 | 03:15 PM
dugeman's Avatar
I just purchased a hurricane efi single plane for sbc , they can be purchased polished or not . Found it new on e-bay , lines up port wise well , I'm going to convert the heads to std. sbc to match intake bolt pattern , it appears that if you try to convert the intake to lt1 bolt pattern the center bolt holes will interfere with the intake runners.
Old Nov 19, 2009 | 01:54 PM
roguedriver's Avatar
There is some interference, but not if you take a little material off the runners. I did and didn't have an issue. The Vic manifold is real thick on the runners right where the bolt heads interfear, so taking off enough material to get them to work is no problem, then use a small head 12 point 3/8" bolt and your good.
Ken R.
Old Nov 19, 2009 | 02:02 PM
jay_rich's Avatar
Ken R.
Just what I was looking for! I just ordered my intake too!
Jay
Old Nov 19, 2009 | 02:30 PM
4-RILLA's Avatar
WHats the Ball park for getting the Super Vic operational on an LT1...if you already have TB and injectors you would need the following correct?:
Holes drilled X amout $$
Fuel rail=X amount$$
Thermostat hole plugged=X amount $$
Distributer hole welded ****=X amount $$
Intake runner portwork for port alignment=X amount$$
Holes drilled for Misc Vacuum fittins from the LT1 manifold=X amount$$
Nitro Daves TB adapter=X amount$
I did an estimation juss kinda half assed guessing what it would take, and come up with about $1600 to get a Vic up and running on an LT1..am I ballpark?
Old Nov 19, 2009 | 05:41 PM
jay_rich's Avatar
depending on how you go about...
Me...
Intake-$140
Vortec distrib -$175
Injector bungs- free
hole mode- free
welding/cutting thermostat-maybe $20-30 bucks (good friend welds)
Throttle body-600
Throttle body hat-$200 or free if I build one at work.
Rails- modify LT1 rails (already modded for -8an)
Parts I sell...
Ported intake-$150
BBK TB -$225
TF elbow-$65
Random other ****...
So since I work in a machine shop and pretty well build everything myself it shouldnt be bad!
Jay
Old Nov 19, 2009 | 05:44 PM
4-RILLA's Avatar
Whats the vortech distrib...is that he discharge tube?
Looka like after you sell your parts..you will be under a grand completed
Read original posts...looks like are are planning on a Vortec Distributor...
Old Nov 19, 2009 | 09:37 PM
jetjoe's Avatar
Me...
Intake-$140
hole mode- free
Throttle body-600
Parts I sell...
Ported intake-$150
BBK TB -$225
TF elbow-$65
Jay
Where are you getting a Super Vic EFI for $140.00??
Old Nov 20, 2009 | 09:03 AM
jay_rich's Avatar
its a non EFI, i am getting a regular one and having someone weld bungs. Getting it from a friend.
Jay
Old Nov 20, 2009 | 09:06 AM
jay_rich's Avatar
Sorry yes a vortec distributor, Taner(9sec6spd...now 8sec6spd haha. on the board is running one on his LT1, thats who im getting it from bc he had an extra
still talking with megasquirt on which route to go for my ignition.
Jay
Old Nov 20, 2009 | 10:01 AM
jsetzer's Avatar
Jay
Let me know if you need any help with MS decisions.
Old Nov 20, 2009 | 04:04 PM
jay_rich's Avatar
haha I was about to PM u lol,,,PM sent
Jay
Old Nov 20, 2009 | 05:29 PM
jakesz28's Avatar
Ken R.
But using a sbc intake bolt pattern gives you more options on gaskets. You can get them in different port sizes and differnet thicknesses.
Old Nov 20, 2009 | 11:20 PM
jetjoe's Avatar
Jay
O.K. The link in the OP was for the 29135 which is the EFI version. With the Vortec dizzy, you should have enough signal to run coil packs with the MSII.
Good luck and keep us posted.
G-BODYT56
Jan 14, 2022 11:14 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
