Baro Update RPM Threshold
Old Nov 12, 2009 | 11:48 AM
cleangene's Avatar
can anyone tell me what this is for.
Old Nov 12, 2009 | 04:51 PM
shoebox's Avatar
RPM threshold the Baro is updated (or maybe not updated)at? Do you have specific Baro update needs?
Old Nov 12, 2009 | 09:18 PM
dookie454's Avatar
The barometer in the LT1 is also the MAP sensor, GM's way of saving money on another sensor, I believe alot of people use it. Baro modifies the base fuel calculation.
The trick to getting an accurate Barometer reading from the MAP sensor which is plumbed to the intake manifold, there's certain conditions which the Intake manifold is very close to Ambient pressure, and that's low RPM and high TPS.
So, when your driving in the Mountains and climbing elevation there's two ways the PCM gets a baro update to keep fueling accurate, than that's during crank or something and the other is when parameters in the "Baro Update RPM Threshold" is met.
NA (no turbo or Supercharger) you wont need to change it, if you run boost, a problem arises where the BARO is resetting (updating) when boost is building since the stock RPM for the resets (or updates) is high enough in the RPM range. Since it starts at ambient pressure and only builds/resets with boost, it alters the fuel calculation somewhat inconsistently since if you rev over the update limit then enter boost the Baro will not update, so you end up with two possible fuel calculations.
To make this work for boosted applications, simply lowering the RPM threshhold to something like 1200-1500rpm is usually all that's needed, that way it can still reset/update, but not when it's sensing boost.
Old Nov 13, 2009 | 01:32 PM
cleangene's Avatar
thanks for reply, I like learning a little more about tuning, who knows when I may need it.
Old Nov 14, 2009 | 06:58 AM
NJ-LE's Avatar
Question
Question:
Does the MAP sensor have a separate port (open to atmosphere) used for the reset? If not, then, wouldn't it be better to raise the "Baro Update RPM" value above your red-line? Unless you're in the mountains, the initial, pre engine start value should be more accurate than a guess at what RPM and TB opening would have the intake manifold at atmospheric pressure.
Old Nov 15, 2009 | 08:20 PM
dookie454's Avatar
[QUOTE=NJ-LE;6172184]Question:
Does the MAP sensor have a separate port (open to atmosphere) used for the reset? If not, then, wouldn't it be better to raise the "Baro Update RPM" value above your red-line? Unless you're in the mountains, the initial, pre engine start value should be more accurate than a guess at what RPM and TB opening would have the intake manifold at atmospheric pressure.[/QUOTE
The MAP uses the Manifold Air Pressure as what it's sensing.
If you raised it to redline then it would be resetting all the way to redline.
Old Nov 15, 2009 | 10:11 PM
NJ-LE's Avatar
Dookie454:
Thanks for the info ... I mistakenly thought the Baro reset meant it would try to get a fresh baseline reading at that rpm. If I understand correctly what you're saying then the "baro reset threshold" is where it STOPS taking new readings. (I still use the stock MAP sensor. I've been reading the 2 bar tuning stickie but don't feel I understand it enough to try ... I only got a baby puffer anyway!)
Old Nov 16, 2009 | 07:37 AM
onefastmx5's Avatar
Mines set at 3600, does that sound about right?
Old Nov 16, 2009 | 01:22 PM
NJ-LE's Avatar
onefastmx5:
3600 rpm is what my factory stock value was.
Old Nov 16, 2009 | 02:45 PM
dookie454's Avatar
Originally Posted by NJ-LE
Dookie454:
Yes, the value is where it stops taking updates.
The stock value (3600) is fine unless you have a 2bar MAP and a 2bar sensor and a supercharger/turbo.
Injuneer
Apr 25, 2022 06:22 PM
Aug 24, 2015 06:41 AM
techstar
Aug 6, 2015 11:20 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
Boss002
Jul 9, 2015 03:33 PM
