1997 Z28 Mid-Tube Pacesetter help
Old Nov 12, 2009 | 12:36 AM
kljklfdi's Avatar
has anyone put in pacesetter mid-tubes on their car? If you do how did you do it without lifting the engine. I tried going underneath the car but kept getting hung up. I'm think about taking out the heads and doing that way but i don't want to chance having to buy head gaskets again and possibly another bolt kit. And i made my own egr block off plates, will that make the engine run crappy or have just a light come on.
Old Nov 12, 2009 | 10:08 PM
madhatter's Avatar
zI've never installed Pacesetters, but have done a lot of headers. You may have to lift the motor, which is easy. Place apiece of wood on the jack and support the oil pan. Then remove the bolt from each side. Once the retaining bolt is out start lifting the motor a few inches. They should slip right in after that.
ScottZ
Mar 3, 2004 01:34 PM
turbo_Z
Aug 19, 2002 10:50 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
30thZ286speed
Aug 3, 2002 04:54 AM
