right rear making noise and sagging help!
Old Nov 9, 2009 | 12:05 PM
mknabz28's Avatar
Well my girlfriend was driving my car with me in it and we turned into a parking lot and boom...big *** pothole. I had to get out of the car and check it cause it hit so hard i thought it might have cracked my rim or blown my tire
Anyway everything seemed ok so we continued on. I must not have noticed it for a day or 2 cause my subs are so damn loud but we were driving with the music of and what sounded like the right rear was making a screeching kinda hitting noise that is very annoying.
So I was looking at my car and noticed that the right rear was lower than the rest of the car. I found i could fit 3 fingers between the top of the left rear tire and the fender well, but i could not on the right rear.
I jacked up the car thinking that it was a broken spring but the spring seemed to be fine, also the shock wasnt leaking oil or anything (unless they're gas charged im not sure they are stock)
Sorry for writing a novel on it but I wanted you to know exactly what happened because I would like to fix it as soon as possible.
Btw to make matters worse I got a call today and I got laid off...
Old Nov 10, 2009 | 09:37 AM
mknabz28's Avatar
anyone? this is driving me crazy and i cant figure out what the problem is
Old Nov 14, 2009 | 07:13 PM
NEWBIE T/A's Avatar
Question Bad axle bearing ? Bent axle tube ?
Both are WAGS, admittedly. I don't know if you can bend a lower control arm, but even if you could or did , I don't see how that would cause a screeching noise.
Perhaps this bump will serve to allow someone else to come in and blow my theories out of the water - I am OK w/ that.
Good Luck !
Britt
Old Nov 19, 2009 | 03:00 PM
ZDriver96's Avatar
only way to know dude is pull that tire off and look.. You'll be able to figure it out once you do that..
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
