Help with rebuilding 350
Old Jan 20, 2003 | 07:12 PM
RANGER'sIROC's Avatar
I need your help...I have a good 350 disassembled engine. It is an 87 non-roller truck block. It appears to be in great shape with almost no ring ridge and all the bearing look good too.
The heads are 1.9x1.5 I used a ruler to get this, the casting # are 14102193. The pistons are dished with 4 valve reliefs. I am trying to get away with as little money as possible. It will be replaceing my 305 TPI. I was planning on doing everything myself with the help of a rebuild kit from Summit/Jeg's etc. 1. Should I use the same pistons, are they worth anything. 2. the heads are these anygood, and what are their cc's? Any other help would be appreciated. Thanks Ryan
Old Jan 20, 2003 | 10:03 PM
AutoRoc's Avatar
yujyt
I would only guess that the pistons are a low compression design made for a truck and towing and for use with 87 octane, etc,etc...
I would buy a rebuild kit and send all of your parts to a trustworthy machine shop for all of the required machining work and assembly. They could also clean your heads up, pocket port and polish them a little, install new seals and guides, valvesprings and retainers also. They would be new heads basically with a little extra power!
All depends on what you want to spend i guess. Goodluck! Good machine work is definately important, don't forget that.
edit: oh yeah, I would choose a compression ratio in the 9.0-9.6 range for the best pump gas use with you stock iron heads.
LT14LIFE
Nov 15, 2015 06:22 PM
Bxlt1
Sep 29, 2015 03:18 PM
HAWG
Sep 25, 2015 11:41 AM
Z Power
Sep 19, 2015 11:19 PM
