Is this Fuel Pump any good?
Old Sep 13, 2009 | 07:44 PM
Need4Camaro's Avatar
Looking to support around 400 - 450 RWHP out of an LS1 or LQ9, preparing for a motor swap and I was just wondering if this was any good or should I look elsewere?
Edit: Stupid me forgot to post the link
http://cgi.ebay.com/ebaymotors/255LP...Q5fAccessories
Old Sep 14, 2009 | 07:22 AM
AL SS590 M6's Avatar
If you go to TRE's site they sell Walbro 255s for $5 than the one that you linked. I'd get the real deal.
Old Sep 15, 2009 | 10:39 AM
Mystery Bird's Avatar
I had one... it lasted 20 minutes.
Old Sep 15, 2009 | 07:09 PM
- Bet you were pissed, having to drop the rear again 20 minutes after it was assembled...
Old Sep 16, 2009 | 06:10 AM
I was so pissed I cut the hole in the truck for a trap door which I said I wouldn't do. This time it only took about an hour from start to finish instead of 4-5 hours dropping the tank and everything in it's way.
Old Sep 20, 2009 | 09:31 PM
30th6's Avatar
you can get a walbro for under 99.99 shipped.
Old Oct 24, 2009 | 02:57 AM
Do the Walbro 255's require any additional wiring or are they direct plug and play? If they are not plug and play, are there any other decent pumps that are plug and play?
Old Oct 24, 2009 | 10:31 AM
BC2002SS's Avatar
I have one in my Fiero for three years, just don't ever run out of gas or it will be scrap. if you drive long distance it can over heat and lose pressure also. That happened to my nephew driving from CT to NC with two different Walbro 255's
Old Oct 24, 2009 | 11:12 AM
rod442's Avatar
Must be certain cars are more susceptable to the low fuel thing. I have one in my mustang and firebird and treat em just like oem. IE I run em as low as I feel like for fuel, and haven't had a problem. 25K in the stang, and 45K in the firebird.
As for the long distances, had no issues there either. I drove 1200 miles from MI to TX and only stopped for fuel when it got low. Then straight back on the road.
Old Oct 24, 2009 | 11:26 AM
BC2002SS's Avatar
you might have more left in the tank when it shows that it's low. the fiero tank is flat on the bottom
Old Oct 24, 2009 | 06:37 PM
But can I use the stock wiring when installing a Walboro or do I need to modify some things?
Old Oct 24, 2009 | 06:50 PM
WhiteHawk's Avatar
Spend a couple bucks and get one with an install kit for an LS1. You need to make a few tweaks to get it to work right.
-Geoff
Old Oct 25, 2009 | 10:43 AM
-Geoff
Thanks, where can I find one with the LS1 install kit?
Old Oct 25, 2009 | 04:10 PM
WhiteHawk's Avatar
Probably most of the board sponsors sell them. Try Thunder Racing.
-Geoff
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
