Corvette Converter good Idea.
Old Jan 19, 2003 | 12:36 PM
iroc_cragg's Avatar
I have a chance to get a good deal on a 89' Corvette Converter. It has a stall rating of 2025 RPM. Would it be a good choice to add that to a 85' IROC 305 TPI with Headers, Catback, and other small mods. I would appricate any replys about the corvette Converters. Thanks
Old Jan 19, 2003 | 02:51 PM
brodyscamaro's Avatar
i have that convertor i would not recommend it for you
Old Jan 19, 2003 | 03:46 PM
Ski89Z28's Avatar
I have a 2500 stall and would recommend that one.
Old Jan 19, 2003 | 04:48 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
I wouldnt pull the tranny just to install that converter, but if you have it apart, then yes, do the upgrade. And you better be getting it for a cheap price, since its a used stock converter.
Old Jan 19, 2003 | 06:47 PM
iroc_cragg's Avatar
Why would u not recomend the Corvette Converter brodyscamaro, Why would it not work well for me.
Old Jan 19, 2003 | 08:35 PM
i dont think its worth the trouble of pulling the tranny. i noticed no difference in performance (butt dyno) when i changed to this convertor. so i am just saying you might pull the tranny put it in put the tranny back in and be a bit disappointed...
Old Jan 20, 2003 | 07:06 PM
iroc_cragg's Avatar
Does anyone else have the Corvette Converter in there thirdgen. How did it work for u. Some of the other people I have talked to said that it worked great for them.
Old Jan 20, 2003 | 08:22 PM
mrr23's Avatar
well you and i have talked over at iroczone. i have it in mine. hit a best of 1.824 60ft. currently have the zz4 cam in the motor. flashes to 2400-2600 range.
Old Jan 21, 2003 | 07:10 AM
IROC5.7TPI's Avatar
Any converter with a higher stall speed than stock will make a performance improvement as long as you don't go so high as to take the engine out of its useable powerband.
A stock Vette TC will make your 60ft times come down nicely if you use some decent rubber to help with traction.
I would recommend if you're buying a new converter to go with a 2500 rpm or even a 3000. I had a 2500 in my car and I know it made a big improvement. I now wish i had a 3000.
Old Jan 21, 2003 | 08:15 PM
CanIroc's Avatar
I have to disagree a bit. Two years ago I put in a Vig 2800 behind a stock cam and heads L98 IROC. It flashed around 3200. Although I got some great 60 ft times (best of 1.79) it did nothing for et and I actually lost mph.
Oh, and launching on the street was a real treat too!
I think it stalled too high in the rpm range.
I ended up selling it and putting the stock one back in but I'm considering trying out the vette convertor too.
Bob
Old Jan 21, 2003 | 08:24 PM
IROC5.7TPI's Avatar
I know it made a huge difference on mine in 60ft. I went from a 2.06 to a 1.96 both on bald street tires. I had other problems that prevented me from making a solid 1/4 mile pass so I couldn't get a before/after all the way through. In the 1/8th I went 9.38 stock, and 9.22 with the 2500 tc. Maybe anything more is too much for stock.
Feffman
Oct 9, 2015 05:42 AM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
thenewkid
Nov 27, 2014 09:41 AM
