metal in oil pan
Old Jul 11, 2009 | 04:44 PM
watxson's Avatar
metal in oil pan
Hello everyone today i went to get an oil change and they found small metal cylinder pieces attached to my magnetic cap. they are all identical and there was about 15 of them. I have absolutely zero engine noise but my car does seem to need to be balanced do to some rumbling at higher speeds or turns. Other then that there is no noise. I hear nor feel anything wrong with the engine. My oil was changed about 2 months earlier and these peices were not found. the people had no idea what it was because they are not shavings they are identical cylinder peices of tiny metal. any ideas?
car is a 99 z28 ls1
Old Jul 11, 2009 | 05:05 PM
watxson's Avatar
BTW each of these pins are not hollow they are solid metal no holes in either end
Old Jul 11, 2009 | 07:23 PM
Kevin Blown 95 TA's Avatar
Rocker arm bearings?
Old Jul 11, 2009 | 08:23 PM
watxson's Avatar
i googled this and they seem to be the exact things that were found in my oil pan.....any suggestions on what i should do? does this have to be replaced? how much does it usually cost? what should i do about thinking some of these are lose floating around?
Old Jul 11, 2009 | 11:23 PM
BandDirector Blk98ZM6's Avatar
Sounds like the infamous rocker arm needle bearings. Reseach it at ls1tech.com and you'll find tons of info and what to do about it.
Old Jul 11, 2009 | 11:43 PM
watxson's Avatar
k well i understand what happened but it seems as if the needles are nothing worry about because there to big to fit through to get filtered through the motor....so in time with oil changes and such they will come out....is this ok to drive for another week until im able to have the money to get it repaired?
Old Jul 12, 2009 | 05:40 AM
AL SS590 M6's Avatar
NO it's sounds like the failed rocker arm hasn't caused any other damage to the motor but it or they could. Either find the money for a new set of rockers, get some used ones to replace the failed ones, or park it until you can get it fixed.
Old Jul 12, 2009 | 10:56 AM
Kraest's Avatar
Retired
I'm sure that they came out sometime during a little spirited driving, but honestly you don't know when... could have been a 2 months ago or could have been yesterday. I wouldn't risk it now that you know about it.
Get a new set of rockers. They are easy to change on an LS1.
Old Jul 12, 2009 | 12:18 PM
watxson's Avatar
thanks for all your help guys
any ideas how much this is going to cost me if i take it to get repaired rather then fixing it myself..?
Old Jul 12, 2009 | 12:25 PM
SheldonZ28's Avatar
Either way you will need to pay for new rocker/s.
Figure you pay labour to take off the coils, remove the covers, locate the bad rockers, unbolt them, replace the rocker, put the bolt back in, tq it, cover back on etc etc.
Id say you can expect to pay 2-3 hours labour. Its an extremely easy process, you need a rachet with 10mm sockets to remove coils, 5/16" socket to remove the cover, and loosen rocker bolts, then a tq. wrench to get the bolts back to 18 lb/ft.
Id seriously recomend you do it yourself and save the $200+ Labour
Old Jul 12, 2009 | 12:35 PM
Marc 85Z28's Avatar
Rocker arm bolts are 22 lb/ft.
www.ls1howto.com has a write-up for rocker arm replacement. It is for aftermarket adjustables, but it will still help.
Where are you located? I've got some low mile used rockers in great condition, cheap.
Old Jul 12, 2009 | 02:28 PM
Chrome383Z's Avatar
I'd either get the Comp replacement bearings or send them to Harland Sharp and have them replace them... Then you can forget about them.
Old Jul 12, 2009 | 04:58 PM
watxson's Avatar
located in northeast, pa
should i be worrying about these pins? im being told by numerous people, no....but i still worry? should i drop the oil pan? could they be filtered through the motor. i was told there 66 and couldnt be filtered through
Old Jul 12, 2009 | 05:43 PM
Marc 85Z28's Avatar
Pulling the oil pan off is a big PITA. Usually most of the needle bearings stay in the rocker, not all fall out. And when they do, most get caught in the casting ridges and flashing in the oil pan under the baffle and are for the most part harmless. You could drain the oil and stick a flexible pen magnet to try and fish out what you can if it bothers you.
Old Jul 12, 2009 | 06:10 PM
watxson's Avatar
ok, thanks
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Mar 15, 2015 07:01 PM
