BBK vs: LSX
Old Jul 9, 2009 | 11:49 PM
bwarren337's Avatar
BBK vs: LSX
I was doing some research and was trying to compare the two. the BBK SSI intake manifold vs: FAST LSX Manifold... First i Compared the price
BBK- $470
BBK 85mm TB-$300
$770
FAST LSX-$880
FAST LSX 92mm TB-$380
$1260
Then i was reading a dyno book and the gains were just about even... has anybody had any experience with either of these... Im looking to try and save money if possible.. any suggestions or input? Thanks
Old Jul 10, 2009 | 06:25 AM
AL SS590 M6's Avatar
BBK- $470
BBK 85mm TB-$300
$770
FAST LSX-$880
$1260
What are you putting it on? That will help us point you in the right direction.
Old Jul 10, 2009 | 07:50 AM
bwarren337's Avatar
well i was thinking of running nos on it in a couple of weeks they both have nos ports on the manifold..
Old Jul 10, 2009 | 09:38 AM
Rice Killer87's Avatar
What motor and whats dont to it first of all?
Old Jul 10, 2009 | 10:40 AM
bwarren337's Avatar
its an 1999 camaro z28 LS1...i put 3" headers on it..SLP lid..K&N filter.. SSRA..thats all that is done to it right now..
Old Jul 10, 2009 | 11:51 AM
Marc 85Z28's Avatar
The BBK is a complete waste of money, in all applications. You should go with the LS6 intake. It will cost much less and make more power. It won't have any sealing issues either.
You don't need nitrous provisions in the intake for anything close to what you're going to do with it.
Old Jul 10, 2009 | 03:14 PM
bwarren337's Avatar
so what makes the BBK such a waste of money... Ive heard alot of good things about the LSX but very pricey.. if anyone has dyno sheets or could explain a little bit more on why changing the Manifold is good..
Old Jul 10, 2009 | 03:42 PM
bwarren337's Avatar
I would eventually put a new cam in
Old Jul 11, 2009 | 08:46 AM
It's an aluminum heat sink making it harder to get consistant power that doesn't make any more power than an LS6 intake which can be had for the same money or less used.
Old Jul 11, 2009 | 11:07 AM
bwarren337's Avatar
so the aluminum would absorb heat. does it matter whether i put a new cam in first or put a new manifold & TB on it.i eventually plan on putting a new cam in also would it be best to get the FAST LSX.
Old Jul 11, 2009 | 03:29 PM
Kraest's Avatar
Retired
Generally:
LS6 intake from stock all the way up to cam-swap.
You don't need the FAST unit until you go heads/cam.
I made 514rwhp through an LS6 intake with a P1SC blower and a 212/218 cam in my 97 auto C5.
Old Jul 11, 2009 | 07:24 PM
bwarren337's Avatar
the ls6 doest have the EGR hook up....What would i need to there?
Old Jul 11, 2009 | 09:23 PM
Kraest's Avatar
Retired
Remove the EGR and AIR system and block it off.
Old Jul 12, 2009 | 12:07 AM
bwarren337's Avatar
So if i were to go with the LS6 would i be able to run NOS with no problems... what size TB would you recommend putting on it... Also where would be the best place to get a LS6 manifold for a cheap price but in very good condition or new if possible. I really appreciate all of the help..
Old Jul 12, 2009 | 10:52 AM
Kraest's Avatar
Retired
Run the stock TB or port your own stock TB...It's pretty easy. That'll work with a cam-swap as well.
Of if you absolutely need one, a ported Stock TB for $59 from here:
http://cgi.ebay.com/ebaymotors/LS1-P...mZ200302041935
LS6 intake from Camaroz28.com or LS1Tech.com For Sale section. Used for around $300.
truecontr3
Oct 11, 2015 09:30 AM
pepon214tx
Sep 20, 2015 04:48 PM
95craz28
11
Sep 12, 2015 07:47 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
alphaauto
Jul 26, 2015 04:40 PM
