700r4 TV detent cable install?
Old Apr 24, 2009 | 08:24 PM
Gtpguy's Avatar
Okay, I simply pulled the old one out of the 700r4 without any problems at all. It seems too easy. IS there something in the tranny that I have to pull out and connect to the cable?
Old Apr 24, 2009 | 09:06 PM
crazypurgatory's Avatar
It's been a while since I have done one but there is a rod in the transmission that has a Z bend in it you have to hook the cable onto that.
If you can't get to it your going to have to take the pan off.
Old Apr 24, 2009 | 09:46 PM
Gtpguy's Avatar
I did a google search and saw that little hook. I'm worried unhooked itself while I was routing the rest of the cable through the TPI runners.
Old Apr 24, 2009 | 11:04 PM
Angelis83LT's Avatar
I had to replace the thing with it in the car. that is a TIGHT fit with the fingers. I routed the cable down the back of the engine and made sure everything was lined up. Took a while. That way you do not have to mess around with routing it the rest of the way.
Old Apr 24, 2009 | 11:10 PM
Gtpguy's Avatar
Everything is fine. The biggest PITA was getting the little screw tightened. I lowered the cross member and unhooked the exhaust mount and had just enough room to 1/8 turn the screw loose. But it works now, so I'm happy.
Nov 18, 2023 07:21 PM
jimmybandana
Mar 22, 2015 07:44 PM
CaRParts102
Dec 6, 2014 08:45 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
