still no cranking
Old Mar 24, 2009 | 12:41 PM
mhilton's Avatar
Question still no cranking
Ok, here's my problem; I turn my key on and all the gauges come on. I try to crank the engine and it will not crank, doesn't click or anything, fuel pump doesn't come on either, nor does the security light. I checked my key resistance and my key switch, both are where they are suposed to be at. The car had been sitting for 5 years. I was thinking about changing the computer. I tried to start the car in nuetral and it wont start. I dont think it is the nuetral safety switch. Any help would be awesome.
Old Mar 24, 2009 | 05:06 PM
70cuda's Avatar
power at the starter?
Check the power at the starter, it should be 12 - 14 volts. Start with that and work your way back up the starting system.
Old Mar 24, 2009 | 09:13 PM
JooneJune's Avatar
New Battery or an old one?
Clean the terminals of a new battery, check your grounds make sure they are clean and tight. Make sure the motor has fluids... 5 years is quite some time.
Old Mar 25, 2009 | 08:13 PM
H2O's Avatar
H2O
I had the same problem. No crank, not even with a jump. Figured something must be bad since battery was only one season old. Charged battery...nothing. Took it back to NAPA and guess what? Bad battery. Put in a new one and it fired right up.
I always thought that a jump would overide a dead battery. From what I read from other posts, if the battery is dead, jump might not get the job done.
Old Mar 26, 2009 | 08:20 AM
teke184's Avatar
if the battery has a short it generally won't work. i had one that would start with the shorted battery, but wouldn't stay running
Old Mar 29, 2009 | 08:27 PM
mhilton's Avatar
Thumbs up fuse
It's amazing what a pcm ignition fuse will do. Mine was bad, so now my car cranks!! Thanks for all the info.
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
