TA steering wheel controls for stereo
Old Jul 17, 2002 | 10:18 AM
SLIMJIM's Avatar
Question TA steering wheel controls for stereo
A buddy of mine is looking to buy a '93 Trans Am. It has a factory Delco tape player and factory steering wheel controls. His question was if he changes out the tape player for a factory Delco CD player, will the steering wheel controls still work for the CD player? Thanks for your help.
1995 Camaro Z28, M6, 3.42 gears
Lakewood LCA, Lakewood Adjustable Panhard rod, K&N Filter, ported MAF, Skip-shift Eliminator, B&M Ripper shifter, Hypertech Power Programmer III w/ 160 degree stat, Ground Control Suspension kit (lowered 3") and 18" Eagle Alloys wheels
Old Jul 18, 2002 | 06:52 AM
SLIMJIM's Avatar
Question
TTT
Old Jul 18, 2002 | 07:02 AM
LS1 RULZ's Avatar
Providing that the new CD deck had steering wheel controls to begin with it should work. Otherwise it's anybody's guess whether it will work or not. GM doesn't use entirely different wiring harnesses just because one car has steering wheel controls and another doesn't.
Old Jul 18, 2002 | 07:39 AM
CrAkD X 95TA's Avatar
he'll be lucky if the steering wheel controls still work at all the 93 steering wheel controls were crap they broke like a couple monthes after they left the factory on most cars
CrAkD
Front: alpine type S 6.5
Rear: MB Quart 6.5"
subs: 2 eclipse 12" alum dvc
amps kenwood 500 4 ch
2 kenwood 2ch 600
http://members.sounddomain.com/crakd
Old Jul 18, 2002 | 07:42 AM
maddboost's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SLIMJIM:
</font>
Well Im not sure if it will work for a factory CD player. But if you do buy an aftermarket CD player there are interfaces that you can use that will allow you to use the factory steering controls on a new CD player. As far as the factory CD player I think the cable from the steering wheel plugs into the back of the deck so just look back there.
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Old Jul 18, 2002 | 08:35 AM
LS1 RULZ's Avatar
The steering wheel controls are on a single wire that is part of the main wiring harness of the factory HU.
Old Jul 18, 2002 | 08:46 AM
SLIMJIM's Avatar
Thumbs up
Thanks for all the info. I will pass it along.
Old Jan 7, 2003 | 12:34 AM
firebirdude's Avatar
Grrrrr.... I am the thread that will not die.....AAAARRRRRGGGGGG!!!!!
Old Jan 7, 2003 | 11:06 AM
Ryan94ZA4's Avatar
For those of you with the 93 car, you can replace your controls if they don't work. 92-93 Pontiac Bonneville SSEi's use the same setup.....
AS for using a stock CD unit, you need to be sure it is a 93 unit. I am pretty sure they changed the button values when they went to the new controls. If the 94 still runs old controls, that would work, too.
Ryan
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
Matt97PTA
Sep 13, 2002 09:21 PM
TireSmoke
Aug 6, 2002 10:25 PM
formula79
Aug 6, 2002 11:18 AM
