94+ T56 VSS pulse per mile
I'm wiring in a dakota digital SGI-5 box to convert the signal from my 94+ T56 to my 93 A4 ECM. The original VSS in my 4l60 sent a 4000 ac pulse per mile signal. I've found that the T56 is 17 pulse per revolution, but what does that equate to in pulse per mile so i can figure out my calibration app. Thanks for any help, i guess this is an ok place for this post. Move it if not, thanks
kevin
kevin
kevin
kevin
x28ke, for 1993 LT1's all VSS signals were a 4000 per mile sine wave for both T56 and 4l60 in 1994 they went to a 40 pulse per driveshaft revolution for 4l60E and 17 pulses for the T56. Are you asking how to convert the '94 T56 17 per revolution to the '93 pulses per mile. Figure your tire circumference in inches, divide it into the number of inches in a mile to get tire rotation per mile , then multiply that by rear gear ratio to get driveshaft revolutions per mile, then multiply that by 17 to get driveshaft pulses per mile.. I assume the box converts +5v Dc pulses to AC sine wave pulses. How do you plan on driving the speedometer and cruse control, in '93 they were fed directly from the VSS, not the PCM like 1994 and after lt1's.
thanks for the replies, with bobdec's formula i get that the VSS is putting out approximately 51,000 pulse per mile, which i need to convert down to 4000 ppm. If i can just get the speedo to work i'll be happy, I don't go on long rides very often. lets see if this works, thanks
kevin
kevin
I got it working, wired it in the signal wire right out of the VSS so the speedo reads and the cruise control works. I had to play around with the output type and switch settings to get it to read. THanks for the help!!
kevin
kevin
stockssn2o
May 25, 2015 08:54 AM
