Finally got things set up to tune, and now the questions
Old Mar 7, 2009 | 03:33 PM
That Camaro Guy's Avatar
I got my tuning software (Tunercats) and my cable last week and I had a few things to tie up first. I did my first scan today and I'm left with a few questions.
1. I scanned the PCM and saved the file in Tunercats. I can access it from my laptop but I'm unable to find the file itself. Tunercats lists the file in the "tuner" folder and opens it from there. Upon opening the folder itself, the file is not there. I've tried every which way to copy/move the file and it's not possible. I would like to edit my files on my desktop with my huge monitor, not on my laptop. Tunercats told me in an email that it was OK to install their software on both of my computers with only purchasing one license and I could send files back and forth like I want to. So... Any ideas how to move the file?
2. Error message while opening my .bin file. The message reads:
"The selected source file has been modified and the checksum disabled. The tuner program can not verify that the prover ECM definition file is being used. Proceed anyway?"
Click yes and it opens just fine, with all the tables. I'm using the original PCM in my 94Z and it has been tuned before at a shop in Orlando. I'm using the latest version of Tunercats with the $EE ECM definition file. I think I'm missing something here
3. I was able to scan the PCM and save the file, but I was unable to keep Freescan running. I tried running it in compatibility mode and not in cap. mode, both ways = fail. With my scan master switched off, Freescan would show connected (bytes/second counting up) but no engine parameters. It would only read anything with the scan master switched on. Diagram of wiring:
Perhaps Vista is the problem? Any recommendations?
Old Mar 8, 2009 | 11:11 AM
bobdec's Avatar
Camaro guy.. Assumed you Installed Tuner and also run tuner in XP compatibility mode. Did you try opening folder, select folder tools, folder options, File Types, and make sure .bin file extensions are there if not click New and add it. Another thing would be to open the .bin file w/Tuner and then do a "save as" and save the file as a .lt1 extension file (Tuner will also work with that format) just to see if Vista is having problems with the .bin. Problem is .bin is also used for a lot of video data formats and is also an executable file extent. Vista gets funny at times.. As far as FreeScan did you go to 'Free Scan Operational Mode' section, 'Force Data' and select the interact button.
Old Mar 20, 2009 | 05:06 PM
Solutions:
1. There was a button on the top of the folder that says "show compatability files" after clicking this the .bin files showed up. Easy fix once I realized it was there.
2. Despite that error message, everything seems to be working fine.
3. I tried "force data" and the PCM communicated just fine, thanks bobdec
Uploaded my first tune today and everything worked out just great. I pulled the fan relays and did a precautionary read, then uploaded the file with no problems.
I would like to thank everyone on this forum for all of your posts and information. I've been using the crap out of the search function in my research and am pretty confident I can now safely tune my PCM thanks to your posts.
AdsoYo
May 2, 2018 03:21 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
nophix
Nov 30, 2014 10:26 PM
Hal Fisher
Sep 14, 2002 09:36 PM
