No Start 95 Z28
Old Mar 5, 2009 | 10:33 PM
LT1S10's Avatar
No Start 95 Z28
Engine cranks good, but never tries to fire.
Computer is showing no codes
Fuel pressure is at 40 psi at the rail
Test light on fuel injectors is pulsing
Ran OPTI test from shoebox website...all checks good
Timing light hooked to #1 spark plug wire showing spark
Could it still be the OPTI????
Thanks!
Mike
Old Mar 5, 2009 | 11:19 PM
MikeGyver's Avatar
Hmm... I assume theres proper airflow through the motor?
Old Mar 6, 2009 | 09:58 AM
bobdec's Avatar
If input air is OK (previous post) Even if timing lite kicks off it could be spark is not strong enough (weak coil). After cranking can you pull a plug, see if it's wet (make sure injectors are really spraying fuel). Can you smell gas at the exhaust (flooding). You could also ground the plug threads and see if it actually throws a spark when cranking **try not to ignite any fuel/vapors or zap yourself. Or you could just get ICM and coil tested.. Also I assume you have correct compression AKA: the timing chain is OK.
Noenav
Mar 1, 2019 07:38 AM
HCz28
Jan 11, 2015 11:21 AM
tds1213
Nov 27, 2014 12:55 PM
