Prob starting
Old Mar 5, 2009 | 01:10 PM
cboggs5's Avatar
Prob starting
Last night I noticed my fuel guage was not working properly and I ran out of gas. Now my 93 Z has a problem starting and once while driving it went dead. I did a fuel pressure check and it checked out fine. The fuel pump doesn't kick on everytime I turn the ignition but if I leave the key in the on position and wiggle the wiring harness from the opti to the pcm connection I hear the pump kick on. If I let the car sit for about 30 min it will fire right up but will run for about ten mins and will not start for another 30. Please help.
Old Mar 6, 2009 | 01:34 PM
cboggs5's Avatar
I don't know if this will help but I was driving last night and the car died( like it did before) and when I tried to start it up I heard the most horrible grinding noise I have ever heard on a car. I was coming from under the car. It an automatic tranny and I recently replaced the tv cable. I have been having probs with the shift point and had been told that would fix it. It didn't.
Old Mar 7, 2009 | 12:39 AM
ussj4brolli's Avatar
any issues before running out of gas?
if not sounds like you sucked up the gunk at the bottom of the tank and clogged the fuel filter. the sound could come from eithr gunk comming out of it...or possible the car starving for gas. Change it and see what happends...cheap replacement
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
