Squeak that won't go away
Old Feb 24, 2009 | 12:18 PM
cblinkdude182's Avatar
I have an annoying squeak that is coming from the front driver's side and I can cause this squeak by driving over a small bump especially at low speeds. I can also park the car and push down on the front fender and cause the noise. I have tried spraying some WD40 all around the shock and spring area and surrounding parts and the sound goes away for a little while then comes back. I have also noticed that if I go through a water puddle on that side the squeak goes away temporarily as well. Any ideas where it's coming from specifically and how to stop it permanently?
Old Feb 24, 2009 | 01:17 PM
JohnD's Avatar
Read down a couple of posts. Mine was the swaybar bushing.
Old Feb 24, 2009 | 01:38 PM
km9v's Avatar
Swaybar bushings. Replace them.
Old Feb 24, 2009 | 02:19 PM
Link to mentioned part please?
Old Feb 24, 2009 | 06:01 PM
transAMdriv3r's Avatar
x2 for sway bar mount bushings to frame. since you have a z28 it should be 30mm unless you have a aftermarket swaybar.
Old Feb 24, 2009 | 10:14 PM
So do you guys recommend I get polyurethane bushings?
Are these the right ones?
http://store.summitracing.com/partde...rt=ENS-3-5163R
Old Feb 25, 2009 | 06:06 AM
Those would be it, but IMO I would recommend some plain ole' rubber bushings. Those may make noise too since they are stiffer almost like plastic. Just make sure you clean the sway bar really good and add a generous amount of grease.
I haven ran into a problem with them yet, but other people have. who knows maybe they didn't even prep them right.
Old Feb 28, 2009 | 03:22 PM
Ok I went and sprayed a little WD40 on each part one by one to see if I could see what makes it go away. When I sprayed the shock and spring the sound instantly went away but it will come back within a week or two, so what's the deal?
Old Feb 28, 2009 | 04:12 PM
n2ceptor's Avatar
WD40 is a penetrating fluid for metal.... Its not recommended for areas that might have rubber... Use a white lithum grease spray...
Could be the upper insulator????
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
