Picking a set of Brake Rotors?
Old Feb 10, 2009 | 04:47 PM
TheOneIsKilling's Avatar
I am just wondering if someone gave me an option on which Brake Rotor sets to go with for my 1995 LT1 TransAm?
Old Feb 10, 2009 | 05:00 PM
jtarp's Avatar
You posted in the wrong forum. You probably won't get much help. You should get this moved.
Old Feb 10, 2009 | 05:12 PM
CheshireCat's Avatar
You'll get a better response in the suspension, chassis and brakes forum where this will likely get moved.
You can do a search in that forum and you'll get a lot of options.
One popular upgrade for our LT1 cars is to upgrade to the brake system that came on the 98+cars. Bigger rotor, 2 piston calipers = better brakes.
Do a search for "LS1 brakes" you might even find someone selling a set in the parts forum.
If you want to stay with a 93-97 size rotor, a quality stock replacement should be good. There are many people that like the drilled and slotted rotors, but just as many that will tell you that they are not as good.
Good luck.
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
siguy
Nov 27, 2014 10:07 AM
