95z28_m6's Turbo build
Old Feb 7, 2009 | 09:25 PM
RealQuick's Avatar
Another build i am working on. Hopefully he will chime in more details on his setup.
383ci LTX
Custom Hotparts utilizing SLP Dual cat headers
T76
40mm JGS wastegate
56mm JGS BOV
4" A2A IC and 3" piping
Old Feb 7, 2009 | 09:46 PM
ford's Avatar
Nice.... Looks almost like you are adapting your designs every time I see them.
Old Feb 8, 2009 | 08:56 AM
97SS0594's Avatar
man i want one of your kits! but all my money just went into buying a house.
Old Feb 8, 2009 | 07:40 PM
95z28_m6's Avatar
About the car.
1995 z28 m6
GES 383 short block
LE2 heads
single plane intake
solid hydrolic roller cam (still not shure on the specs yet)
duel in tank 255 pumps
meth injected
motor will likely see around 18psi
Mcleoud twin disk
strange 12 bolt w/4.10s
summit star wheels 10.5 x 15 rear 4 x 15 front
m/t et streets
car is also getting a cage
The hotside is looking awesome! I cant wait to get this thing together. Nothing quite like getting to build the car of your dreams! Thanks for the pics RealQuick.
Old Feb 8, 2009 | 07:55 PM
RealQuick's Avatar
No problem bro! Shoot me an email about the cam. I can help ya with specs...
Jon
Old Feb 8, 2009 | 09:19 PM
reamo04's Avatar
god those headers look funky
Old Feb 13, 2009 | 08:22 AM
RealQuick's Avatar
Hotparts are done... didn't get a chance to post pics. I will have pics tonight.
Old Feb 14, 2009 | 02:52 AM
engineermike's Avatar
Originally Posted by 95z28_m6
single plane intake ...motor will likely see around 18psi.
The T76 will not allow a 38X cid engine rev high enough to get any advantage out of the single plane conversion.
It's been proven on the dyno that the SP doesn't help any until 6200 rpm, depending on combination. That combo will peak at 5800 at best and drop quick above there due to the turbo choking.
Consider saving some money/effort and making more power by using an LTx intake.
Old Feb 14, 2009 | 10:43 AM
RealQuick's Avatar
Some pics before the DP was finished.
Old Feb 14, 2009 | 09:53 PM
RealQuick's Avatar
the finished DP (designed that way for easy installation)
Old Feb 15, 2009 | 01:45 PM
jay_rich's Avatar
Wow lookin good! I wish i could bring my passenger header under the accesories but my stupid 3rd gen pitman arm steering box setup ruins that.
Jay
Old Feb 16, 2009 | 03:05 PM
RealQuick's Avatar
Thanks!
Old Mar 16, 2009 | 10:45 PM
RealQuick's Avatar
Update... cold side... some welded up and some tacked for mockup.
File Type: jpg
Old Mar 23, 2009 | 03:21 PM
RealQuick's Avatar
Kit is done. Just waiting on a few miscellaneous connectors/clamps/fittings.
Old Mar 23, 2009 | 08:53 PM
TA Dreaming's Avatar
Will you be able to post a dyno graph of the car or will that be the owner's responsibility?
