Fuel cell for liquid-air intercooler.
Old Aug 22, 2002 | 12:45 PM
BLOWNBIRD's Avatar
Question Fuel cell for liquid-air intercooler.
What size fuel cell is needed for an air to water intercooler? I have a Vortech Mondo cooler, and want to put the water resivoir in the back. Do I NEED a 5gal cell, or can I get away with something smaller? I had thought about putting the cell in the nose of the car since the bumper and supports are removed, and had wondered if I could use a smaller 3gal fuel cell. Any tips or advice would be greatly appreciated.
Old Aug 22, 2002 | 01:07 PM
Vortech396's Avatar
I am using a 3 gallon fuel cell for my water/ice.I'm running the Vortech Aftercooler.I guess more might be better but I have dynoed 6-7 times in a row and my ice wasn't even melted yet in the 3 gallon cell.
http://www.96silverz.cz28.com/images...rwatertank.jpg
seeya
John
Old Aug 22, 2002 | 02:13 PM
Guido's Avatar
I feel better about using a 3 gallon cell now myself. Mine is in the back too.
-Curt Ailes
86 IROC w/ T88 Turbocharger
http://www.hustonstreetracing.com
Old Aug 23, 2002 | 12:27 AM
zturbo's Avatar
I am using 5 gallons myself in the rear This will feed both my intercoolers
Basically what I did was figure how much the pump is going to circulate. Then figure out how long with my staging the car is going to need time wise. I think with the pump i picked i would need right around 4 gallons so I will have a surplus plus use the excess area to set the car up ballast wise if i need some more weight in the car. I know it is not much but still.
Only regret I have is I got one of the 5 gallon alum cells from Summit (great cell) but the plastic is better for the cold water wont absorb heat or shed the cold as much.
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
My Car
Old Aug 23, 2002 | 07:38 AM
Guido's Avatar
Steven,
Buy some insulation you can put on it. I have an aluminum cell too (it's a homebuilt setup) and I was thinking of doing that.
Where I work, we build equipment that cools atmosphere gases. The gases run through a bundle of copper tubes that are inside a large tube (like 10" diameter). Around the outside of the big tube, we glue on this black 1" thick industrial insulation.
Stuff would work good for you too and it doesnt look bad either.
Just a suggestion of course.
-Curt Ailes
Old Aug 23, 2002 | 08:19 AM
Dams76's Avatar
I use a 5 gallon upright Jaz fuel cell for my Vortech aftercooler. with some bending, cutting, and pounding it fits nicely in the spare tire well. I will see if I can get some pics up for you.
DavidS
Old Aug 23, 2002 | 10:32 AM
BLOWNBIRD's Avatar
Thanks everyone, this is exactly the type of feedback I was looking for! I hadn't thought about the issues between the aluminum and plastic cell's, looks like I should consider the plastic over the alum.
Doesn't the efficiency of the core play a role in the sizing of the cell? Seems to me that the more heat you are pulling out of the air charge, you would size the tank accordingly.
Maybe I should just stop pulling my hair out and just go for the 5gal. plastic cell. I just hate adding the extra weight if I only need a 3gal.
Any more suggestions?
Old Aug 23, 2002 | 10:13 PM
zturbo's Avatar
Blown
Spearco recomends a certain flow which i found a pump that met that requirement (was not going to buy there overpriced pump) the spearco pump is like 200 bucks where if you search you can find the exact pump for 69.00. They say if the water is too fast it will not transfer the heat good and if too slow will heat up too much.
Curt
Insulation is a great idea. I will try to find some and will wrap the water cell up with it.
Steven
TURBO=TORQUE
TORQUE=FUN
My Car
Old Aug 27, 2002 | 09:30 AM
blown interceptor's Avatar
I am also looking to do a 5 Gallon fuel cell in the spare tire compartment. Does anyone know the best and what kind of pump to use? I changed from the stock Vortech pump(2GPM) to an audi water pump(6GPM). Will that pump work? Or is there a better one to use?
Anyone have a few pic's so I can reference to?
2000 Z-28, Dark Blue,M6,3.73,
SS Hood,K&N
RK Sport Front& Rear Sway Bar Kit,Eibach ProKit,Bilstein's all around,Hotchkis PanhardRod,
Vortech 9psi w/Aftercooler, Upgraded aftercooler, JBA
Headers, FRA, TB Bypass,
Ed Wright Tuning, Holley Intake,
BBK 80MM TB,
Awaiting install SMC Alcohol Injection.
498rwhp 425rwtq
Old Aug 27, 2002 | 02:53 PM
Guido's Avatar
I bought the one out of the spearco catalog. Although I didnt pay their prices. I got it from my local industrial supplier at about %40 of the price spearco wanted.
-Curt Ailes
Old May 28, 2003 | 01:02 AM
89ProchargedROC's Avatar
back from the dead....LOL
Question regarding water pump options
I was curious what seems to be a good GPM pump to use, how much would be enough?
I plan on using a 3 gallon fuel cell and putting it in the rear of the car
thanks
Dec 1, 2016 05:37 PM
NewsBot
May 16, 2015 04:00 PM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
cmyname1
Feb 19, 2015 08:38 PM
BIGCOWL-IMP
Jul 22, 2002 04:26 PM
