Clutch or motor mount or what?
Old Oct 30, 2008 | 04:26 PM
billscamaro's Avatar
6 months ago i replaced my clutch and when finished, my car has had a bad vibration that shakes the entire car. It only happens when the clutch is engaged from a dead stop and when engaging it when downshifting. And when the engine is under load and i press the clutch quickly, i hear a single knock.
Someone advised me that maybe my drive shaft needs to be checked or most likely the yoke or universal joint needs to be replaced on it. I replaced the rear end with a moser 12 bolt recently and the problem still exists.
The vibration goes away if i rev the motor to 2k rpms when i release the clutch. If i do not rev it up a small bit, the car violently vibrates and you can hear a ticking sound underneath the car. (can't really tell exactly where) I have never experienced this at all until i replaced my clutch and perhaps i screwed something up during the install.
As always, i appreciate everyones input and thanks in advnace.
Old Oct 31, 2008 | 04:33 AM
anyone have any idea?
Old Oct 31, 2008 | 06:25 AM
AL SS590 M6's Avatar
Sounds like clutch shudder to me. What pieces did you use, clutch, pressure plate, flywheel?
Old Nov 1, 2008 | 11:47 PM
not sure, i bought the car with what it has in it, the transmission was shot when i bought it so i put a new one in it and used the textrailia clutch that was in it
so when i get a new clutch the problem will be resolved?
thinkin about gettin the LS7 clutch kit
HectorM52
Jul 30, 2017 11:46 AM
Mar 15, 2015 07:01 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
