what's a 6.0 worth?
Old Oct 18, 2008 | 02:08 PM
axehead's Avatar
what's a 6.0 worth?
a buddy has offered to sell me an '03 that only has 200 miles on it for $300, it has wiring harness & computer. he said that he thinks the ac compressor is bad. is this a good deal? i might put this in my jeep!
Old Oct 18, 2008 | 06:02 PM
WhiteHawk's Avatar
Definitely worth it.
-Geoff
Old Oct 19, 2008 | 12:36 PM
axehead's Avatar
is a 6.0 all aluminum?
Old Oct 19, 2008 | 12:49 PM
86camaro383's Avatar
If its out of a truck, its a iron block.
Old Oct 19, 2008 | 06:12 PM
Need4Camaro's Avatar
Put it in the 93 Z28, I wanna see how that turns out
Old Oct 19, 2008 | 08:51 PM
axehead's Avatar
that would be a sweet project also, but i need v8 power in the jeep. I CAN'T PASS ANYBODY ON THE HIGHWAY! :-)
Old Oct 19, 2008 | 08:54 PM
axehead's Avatar
i think he said its out of a truck, what's the difference in it and an LS2?
Old Oct 20, 2008 | 09:46 AM
Yea but look at it this way, If you put it in the Camaro Z28, your Jeep could get smoked by 10 cars on the highway, and by the time you would have went home, parked, had a snack, checked the news, pull out your Z28, get on the Highway, go to your destination... ..you would pass all 10 cars who passed you earlier + probably 50 more
Old Oct 20, 2008 | 02:48 PM
Rice Killer87's Avatar
Shouldve thought about that before you bought it!
lol
Old Oct 27, 2008 | 05:55 PM
axehead's Avatar
how can i found out the specs on a 6.0?
Old Oct 28, 2008 | 06:11 PM
WhiteHawk's Avatar
LS2 is a similar block, except in aluminum. It has a different cam and different heads. Iron blocks don't need any clearancing to make them strokers, either, which is nice if you want to do some modding.
-Geoff
Old Oct 29, 2008 | 09:34 AM
Chrome383Z's Avatar
Hell yes $300.00 is a good deal.
Put the LT1 in your Jeep.
For no more then you have in the 6.0L spend a little money and stroke that up to a 408ci and put it in your Z28.
Old Oct 29, 2008 | 07:47 PM
axehead's Avatar
after more research i found out that there are two 6.0 truck engines, a LQ9 & a LQ4. anyone know the differences & similarities in these?
Old Oct 29, 2008 | 09:54 PM
Chrome383Z's Avatar
There may be some internal differences, but AFAIK the only major differences are the compression ratios. Supposedly the LQ4 has different pistons then the LQ9 (acc to the truck forums in a quick search).
Either way, doesn't really matter esp if your going to go with different heads.
Go for it!!!
Old Nov 4, 2008 | 10:22 PM
BlackFormulaLS1's Avatar
pull the serial number/ casting number off the block/heads then you should be able to find out exactly what the stock compression ratio is/ cam/ Lb per Hr Injectors/Maf everything..once you know what the engine is, you can get a lot more info as you are researching a Specific engine instead of two or three..
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
