where should I put my Nozzle? LT4
Old Sep 27, 2008 | 08:48 PM
remaxracer45's Avatar
I have a NX wet kit for my car in sig. The car previously had nitrous and the nozzle was screwed into the mouth of the 58mm BBK?. Thus it was spraying into one side of the throttle body and was 2 inch from flap?. I have a k&n cold air a 85 mm maf and a coated vortec elbow that has the divider in it. Trying to find the best way to install as the divider would force it into one side or the other or I could put it by the maf before the divider.
Thanks
Old Sep 28, 2008 | 12:26 AM
Fuels94TA's Avatar
The best spot is 6 inches away from the TB, yes that divider does make it a pain in the @ss. I 've heard of people gutting out a section of the divider.
Old Sep 28, 2008 | 06:36 AM
2000GTP's Avatar
I agree, the Vortec elbow makes distribution a pain in the but. In that case, a dual nozzle elbow, one plumbed on each side would work out pretty good.
Old Sep 28, 2008 | 10:40 AM
if I put it on the maf side of the elbow where there isn't a divider for 3 inches it should be fine? probably just getting a plate as I like the elbow to much
Old Sep 29, 2008 | 09:14 AM
Moshbmx1's Avatar
Or you could take the vortech elbow off and keep that as a spare and put a trickflow elbow on there that doesn't have the divider in it.
Old Sep 29, 2008 | 10:34 AM
mosh how do you like your 685? i just got one at a swap meet for $50.00
Old Sep 30, 2008 | 09:23 PM
Moshbmx1's Avatar
Well i liked it before, now I cant get it to work. I haven't sprayed in about a year because the box's kept going to **** on me and I was just fed up with the whole thing so I never hooked it up completely and now that I moved it back into the hatch area just last week and wired it all up it wont work. So i dont know whether its wired wrong now or what but im about ready to rip the whole set-up out and toss it. But when It worked i liked it, now im just pissed in general
Old Sep 30, 2008 | 10:11 PM
mine has the plugs cut off ($50.00 at a car show) what wires did you have connected where?
Old Oct 1, 2008 | 09:05 AM
Moshbmx1's Avatar
Right now I couldnt tell you off hand. We originally wired it up about two years ago when we mountd it in the glove box but then it kept getting to hot or it didnt have enough power so we moved it into the hatch last year and extended all the wires except for the power wire because I didnt want to mess with it all. So we finally ran the power wire and got it working but I couldnt tell you where we have the other wires connected to right now. We are tearing it apart this weekend to figure out whats wrong and then I can tell you where I have it all connected.
Old Oct 1, 2008 | 11:57 AM
thanks
Old Oct 1, 2008 | 03:27 PM
Stroked96Bowtie's Avatar
http://ltxtech.com/forums/showthread.php?t=657
post#2
Old Oct 1, 2008 | 10:07 PM
Moshbmx1's Avatar
Originally Posted by Stroked96Bowtie
Requires log-in
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
