R12 Hose Replacement
Old Sep 6, 2008 | 07:00 PM
damnyankee36's Avatar
I have an 83 Camaro that was originally non-AC equipped. I installed used factory AC components and now have an operating system. I am using an R12 replacement refrigerant.
The only part that I couldn't find as an exact match was the hose manifold assembly. My engine is an H.O. that requires different hoses that can't be found at my auto parts store. Hoses off a regular Camaro work but can't be routed properly. I have located the correct hose ends and fittings. Can new hoses be re-crimped back on the fittings? Somebody told me that this wasn't possible anymore because the only hoses available are the barrier type which will not fit the old style fitting.
If that's the case, how are replacement hose constructed? Do they have different fittings to mate with the barrier hoses?
Thanks!
Larry
Old Sep 6, 2008 | 10:33 PM
Gord's Green Z28's Avatar
I don't know where you would find the hoses. But barrier hoses are compatible (and preferred) for R-12 systems.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
stopthatman
Feb 9, 2015 09:00 PM
pologreen97z
Dec 2, 2014 10:42 AM
ro2207
Dec 1, 2014 01:02 AM
