msd coil 8226
Old Sep 3, 2008 | 09:52 AM
popstoy's Avatar
msd coil 8226
i recently installed new msd coil on my 95 trans am after driving for awhile when the car enterd closed loop a small miss sprung up, then the car barely stayed running almost like a bad opti.got home checked for codes none where present ,then I put the old coil back on the car and it ran fine .other than getting a bad coil out of the box could the new coil have put extra strain on ignition parts to cause this.
Old Sep 7, 2008 | 11:58 PM
Fatdog2's Avatar
Might buy a new G.M. coil.A Accel killed my car on the onramp to a freeway.Stuck for 2 hours.Hope this helps.
Old Sep 8, 2008 | 06:51 AM
shoebox's Avatar
Could be just a bad coil. It happens. Also could be one of the connectors was not making good contact.
Old Sep 8, 2008 | 05:46 PM
n2ceptor's Avatar
Shoebox has been using MSD coil for awhile now, and I have been using Accel coil.... I havent had any problems, nor do I believe Shoebox has either????
As stated, it might just be a bad coil......
Old Sep 11, 2008 | 03:09 PM
93LT1MaroBoy's Avatar
i bought a blaster 2 for my 93 and it would run good then just like die. I bought another one this morning the 8226 and it does the same thing? 2 Bad coils i doubt it. Put the stock one back in had no problems. Any ideas?
Old Sep 11, 2008 | 11:33 PM
shoebox's Avatar
My original MSD coil did die, but it died slowly. I got a warrany replacement for free from them. That was around 9 years ago, LOL! Still using the same coil.
Formula Steve
Sep 19, 2023 08:31 AM
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
Pwilson59
Sep 3, 2015 08:47 PM
canuck94z28
Aug 19, 2015 05:50 PM
