93 Lt1 Difference Between Jet 6 Speed And Auto Chip?
Old Aug 28, 2008 | 03:29 AM
93LT1MaroBoy's Avatar
Does Anybody Know If There Is Any Difference Between The Jet Stage 2 Chip For A 6 Speed And The Auto?
Old Aug 28, 2008 | 12:40 PM
sleeperLT1Z28's Avatar
I think the only difference is in the Idle Speed vs. Coolant Temp in Drive table. If I remember correctly, mine was zeroed out. To be honest though, don't waste your time or money on one of these. I read the Jet chip once I got my Moates.net APU1, and all Jet did was raise the timing at WOT from 38 to 48 degrees. This will of course cause knock retard, but because the table is set so ridiculously high, it recovers to higher than stock timing. They also richened everything up a little bit. Clearly, this is not the best tuning solution. My whole Moates setup cost around $350, and it is absolutely worth the price, especially considering that the Jet chip is about half the cost already. Plus, you can data log with it too.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
LT14LIFE
Feb 9, 2015 09:35 PM
W7Z28
11
Jun 25, 2002 02:23 PM
