No Start, No security light on bulb check
Old Aug 14, 2008 | 04:53 PM
zephxiii's Avatar
I have a 1995 T/A that won't crank all of a sudden. The Security light doesn't even turn on when i move the key from off to On, everything else does a bulb check though. I can't tell if its the VATS screwing up or not because of the light. Is the security light supposed to do a bulb check?
Also by no start, i mean no crank, though fuel pump does seem to prime when move the key from off to on though.
Old Aug 14, 2008 | 08:17 PM
zephxiii's Avatar
Blah, i had the courtesy circuit fuse pulled due to a parasitic drain. Ironically, the security light for the anti theft system works from that circuit, so it was disabled. After putting the fuse back in, i saw that the anti theft system had the car disabled, caused by crappy connection at the resister wire harness that connects the steering column etc.
Amshnock
14
Jan 18, 2015 11:47 AM
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
danielbmx
Aug 27, 2002 11:11 PM
