VRE 383 Turbo LT1
Old Aug 4, 2008 | 07:31 PM
Eric@Victory Racing's Avatar
VRE 383 Turbo LT1
Engine
Displacement: 383 ci
Heads: Stock LT1 Castings, ported by ET Performance
Fuel Injectors: 60# Mototrons
Compression Ratio: 9.0:1
Camshaft: Custom Victory Racing Engines Turbo Camshaft
Throttle Body: Holley 58mm
Intake Manifold: Stock Lt1
Exhaust: VRE Headers, 3" pipe all the way back to 3" Flowmaster Muffler
Fuel System
2-255lph Pumps
Aeromotive Pressure Regulator
Transmission
Transmission: Stock T56 Six Speed
Clutch: Mcleod Street Twin
Rear End
Moser 12 Bolt 4.10 Gears
Turbo Kit Specifics
Turbo: Turbonetics 76mm Turbo
Intercooler: 3" Air to Air Intercooler
Hotside: Victory Racing Engines Custom Headers
Water/Meth: AEM
Boost Controller: Turbonetics Dual Boost Controller
Wastegate: JGS
Blow Off Valve: JGS 44mm
[img]http://victoryracingengines.com/albums/James-***/DSC04081.sized.jpg[/img
Old Aug 4, 2008 | 08:18 PM
RealQuick's Avatar
Nice looking kit! Any pics installed in an fbody?
Old Aug 5, 2008 | 07:39 AM
92LT1RS's Avatar
Eric - killer setup you've got there. What's your projected power level?
I'm finally getting ready to finish the 383 I ordered from you like 2 years ago now. Damn school getting in the way of things.
T. Reeves
Old Aug 5, 2008 | 11:36 AM
JZ 97 SS 1500's Avatar
Very nice Eric....let us know if you need anything. Also give us a call...I have a few LT1 customers that want a turbo kit asap.
Old Aug 5, 2008 | 12:16 PM
T/A KID's Avatar
Wow, thats funny me too.
BTW that turbo setup looks pretty pimp
Old Aug 5, 2008 | 12:20 PM
Old Aug 5, 2008 | 12:21 PM
Give me a call at the shop, and we will get you set up.
586-741-058
Old Aug 5, 2008 | 01:17 PM
RealQuick's Avatar
Looks good Eric! How is the steering shaft clearance? Will it work with a stock shaft, or do you need a manual rack setup?
Jon
Old Aug 5, 2008 | 01:37 PM
cjmatt's Avatar
Is that in the Firehawk? You saving all of your measurements so that You can make cheap quick kits for trans ams also?
Old Aug 5, 2008 | 07:35 PM
No clearance issues at all with the stock shaft. This kit will retain air conditioning too.
Jon
Old Aug 5, 2008 | 07:37 PM
Yep that is the Firehawk I was telling you about. We all all the specs on a kit, and are toying with the idea of reproducing it for resale. You think there would be any interest in it?
Old Aug 5, 2008 | 08:56 PM
94irocz's Avatar
If the price is right they will come
Old Aug 5, 2008 | 11:38 PM
Maybe something like this:
--VRE LT1 Turbo Kit--
-1 3/4" Tubular Headers
-Turbonetics 76mm Turbo
-2 1/2" Crossover Pipe
-3" Down Pipe
-Front Mount Intercooler
-V-Band Clamps on Headers and Down Pipe
-Vibrant Silicone Couplers
-Oil Drain and Feed Lines
-JGS Blow Off Valve
-JGS Waste Gate
-Hi Temp Ceramic Coating Hot Side
-Crushed Silver Coating Cold Side
Old Aug 6, 2008 | 08:14 AM
z96's Avatar
z96
Turbo kit
If the price is right im in!!!!!!!!!!!!!!!
Old Aug 6, 2008 | 05:38 PM
94irocz's Avatar
-3" Down Pipe
-JGS Blow Off Valve
-JGS Waste Gate
For the grand total of??????????????????????????????????????????
