Does this sound like its on par?`
Old Aug 4, 2008 | 02:02 PM
30AnniversaryZ28's Avatar
For the car in the sig, here are my times from the local track the other night. It was at sea level, more or less, and upper 80s. Tires are streets with 30 psi. It's running pretty rich also.
I'm still getting used to the t56 and I can tell it has much more potential with some good tires.
best run was 8.285 @ 85.844 with a 1.883 60'
2nd best was 8.435 @ 81.563 with a 1.99 60'
best mph was 8.639 @ 86.648 with a 2.119 60'
Old Aug 4, 2008 | 02:13 PM
slomarao's Avatar
you need some 4.10's.
How much work is in the heads?
Old Aug 4, 2008 | 02:20 PM
Not much at all. I think just a 3 angle valve job and gasket matching. I believe the bellows are smoothed a little as well. The intake also had some work done.
Old Aug 4, 2008 | 08:29 PM
slowride94z's Avatar
I had an almost identical run earlier this year
8.25 @85.75 with a 1.887 in 60' I ran 1/4 also the time was 12.802@108.36
the point is you probably have a 12 second car na
good job
where did "y'all " run at ?
Old Aug 4, 2008 | 08:45 PM
Yay, 12 seconds. But we ran at Dorchester dragway off hwy 78. Not the best track, but the closest
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
