got some times with the 227 cam and yank 3200
Old Aug 1, 2008 | 10:44 PM
ZL1modified's Avatar
Weather= 73* with 87% humidity
Elevation= 1250'
Best Run= 1.834 60' 8.21@84.59 in the 1/8 and 12.87@105.68 in the 1/4
All this on STREET tires at 32 psi...
i thought i would run a little better but i am happy with the 60's...
i tried launching at 2k once and i spun at least 30' so i then started launching from idl and 60's just kept getting better...
Old Aug 2, 2008 | 02:17 AM
AL SS590 M6's Avatar
Put a tire on it so that you can launch it hard and watch the ets fall.
Old Aug 2, 2008 | 03:11 PM
AutoRoc's Avatar
21 mph gain in the last half doesn't seem right. Check the trans fluid? How is it shifting?
Old Aug 3, 2008 | 08:54 AM
it is wierd that you say that because on my 13.1 pass my trans was slipping or hesitating when going into second...
i'll look into it... thanks
Old Aug 4, 2008 | 06:28 AM
tomcowle's Avatar
Thats not bad at all, my car runs 90 at the 1/8 mile and 114 in the 1/4 mile, thats 24mph on a 11.70/11.80 pass.
Old Aug 4, 2008 | 06:11 PM
slowride94z's Avatar
21 mph gain here
good run by the way
Old Aug 4, 2008 | 06:31 PM
Originally Posted by slowride94z
21 mph gain here
good run by the way
was that gain with nitrous? if so how big of a shot?
Old Aug 4, 2008 | 08:19 PM
no
the 21 mph gain was between the 1/8 mile and 1/4mile speeds
with a 60 hp shot # 30 jet dead off idol in front of maf
1.887 in 60
8.256@85.75 in 1/8
12.802@108.36in 1/4
that's 22.61 mph diffrence between the 1/8 and the 1/4 mile speeds
take the time to let some air out of your tires and pump up the fronts to max, it will help
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
