coil over shocks or lower control arms
Old Dec 24, 2002 | 10:34 PM
94z'sson's Avatar
i was on www.thunderracing.com and they have PA racing k-members which i am looking to buy along with a set of lower control arms that are adjustable but they dont have a set of spring perches so i thought i could try to find a set of coil overs or a set of lower controls arms that are adjustable with spring perches any help would be great
thanks
bud
Old Dec 24, 2002 | 11:30 PM
Stephen 87 IROC's Avatar
You can use the factory A-arms with the PA racing crossmember. They also have a tubular A-arm available.
You can't just install any coilover kit. You still need to use a third gen style front struts then buy the coil over kit to go on it.
The coil over kit eliminates the factory spring and installs a coil spring over the front strut.
All the PA racing products are listed at www.paracing.net
Old Dec 24, 2002 | 11:59 PM
IROCZZ3's Avatar
Re: coil over shocks or lower control arms
thanks
bud
I'm sure PA Racing will build you a set of the adj A arms w/spring perches if you ask them.
I just completed installing their K member and non adj A arms w/ spring perches. Even though they say you can use stock A arms with their K member, it will NOT work. The forward part of the A arm will rub on the crosstube because the stock A arm is too thick. It will actually bind during full suspension travel. I did not want to grind on the A arm or K member because it may weaken that area and cause a crack. I went ahead and got their tubular A arms because it provides a lot more clearance in that area. Now it works perfectly!
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
