H20 powered car from Japan.
Old Jun 25, 2008 | 07:12 AM
Gripenfelter's Avatar
http://www.reuters.com/news/video/po...ideoChannel=74
Old Jun 25, 2008 | 07:27 AM
Threxx's Avatar
This just doesn't seem possible - runs entirely on water with no external input ever other than water??
Surely there must be a big 'con' here or some sort of magic trick or else you'd think something like this would take the world by storm.
Old Jun 25, 2008 | 07:50 AM
shock6906's Avatar
That's what I was thinking too. There's got to be something we're not seeing.
Old Jun 25, 2008 | 08:24 AM
ImportedRoomate's Avatar
Some sort of electrolysis to get the hydrogen from the water? It will take about 13kwh (probably more in real world) to convert 1 gallon of water to hydrogen. That's almost the capacity of the Volt battery. That thing has to have a huge battery that needs to be recharged.
Old Jun 25, 2008 | 08:25 AM
Threxx's Avatar
That's what I was thinking but they claim no external input except water. That would be a huge lie if it requires nightly recharging.
Old Jun 25, 2008 | 09:17 AM
DvBoard's Avatar
Oh "mythical black box" type of powering huh? I will believe it when i see it.
Old Jun 25, 2008 | 12:13 PM
DAKMOR's Avatar
It's hydro-electric dam style power. When you fill it up it goes and starts turning a turbine generating electricity. Then 10- 20% of that electricity is used to power a a pump to recirculate the water back through and start the cycle over and over again, eventually gathering enough energy to use on electric motors to move the vehicle.
Old Jun 25, 2008 | 12:32 PM
routesixtysixer's Avatar
It's the famous perpetual motion machine! It magically turns water to hydrogen with no power required to do so. Um, yeah, I have my doubts.
Old Jun 25, 2008 | 01:57 PM
Mikie's Avatar
Im hoping and praying that this will come to pass and not just some gimmick.
This will be the only way gas prices will fall.
Old Jun 25, 2008 | 02:58 PM
indieaz's Avatar
http://www.citynews.ca/news/news_23767.aspx
But they're in talks with Japanese automakers about the idea and hope it will one day water down your need to ever visit a gas station
IF this were for real, the article would read:
"Toyota Inc. is currently engineering a vehicle to run on this concept and has already purchased the rights to this technology"
Old Jun 25, 2008 | 03:01 PM
jg95z28's Avatar
If that's true, I'm assuming it works on gravity. What happens when you try to go uphill?
Old Jun 25, 2008 | 03:16 PM
Jim the Nomad's Avatar
You CANNOT get more energy out of a system than you put in. It's one of the fundamental features of our universe.
In the system you described, even if there weren't any propulsion involved, you would not generate enough power from the water turbine to pump 100% of that water back through the turbine. Additional power MUST come from somewhere.
I assume that's why they said all you have to do is add water, EXCEPT They didn't mention a turbine.
They said:
Originally Posted by Silly Reuters Lady
"an energy generator takes hydrogen from the water releasing electrons that power the car"
WRONG!
it takes electricity to split the hydrogen and oxygen in water. That's the electrolysis that has been mentioned. You do not gain electricity by splitting hydrogen from oxygen.
You can combine hydrogen and oxygen and get electricity as a byproduct... that's how hydrogen fuel cells work.
In any case, I'm betting that however their system works (if it does work), the price of the energy you use in terms of the potential energy stored in gasoline, is essentially $20 per gallon.
Old Jun 25, 2008 | 03:27 PM
Grape Ape's Avatar
Close. I think it actually dumps most of the water out after it spins the impeller to generate electricity.
Old Jun 25, 2008 | 03:36 PM
jg95z28's Avatar
If that's the case, why not just go with squirrels on a treadmill?
R377's Avatar
Yeah, undoubtedly BS as is presented. I can see some local news show getting suckered by such a story, but you'd think Reuters would do a little better job on their fact checking.
