low coolant light
Old Jun 22, 2008 | 08:29 PM
ablkbrd's Avatar
low coolant light
the light comes on and then like a ninja vanishes only to reapear some other time. i flushed the system in my LT1 and refilled but it is still on ? I know the level is fine but that light is making me crazy!
Old Jun 22, 2008 | 09:11 PM
dre2013's Avatar
its common..faulty sensor. you can replace it, or just unplug it
Old Jun 23, 2008 | 12:36 PM
Slick_Sammy's Avatar
resevoir may actually be a little low, double check it. it will drink some coolant over a number of heat cycles as well as take a number of "burpings" to get all the air out. i freaking hate the LT1 cooling system!
Old Jun 23, 2008 | 04:50 PM
ablkbrd's Avatar
where is the connection so i can unplug it? is it on the rad. itself?
Old Jun 23, 2008 | 06:18 PM
moparman's Avatar
Take the battery out and you'll see it sticking out of the radiator.
Old Jun 24, 2008 | 08:29 PM
smithtim's Avatar
check the level several times; it could just be a sensor or a burb or air, but then again you could have a hole in your head gasket or something like that.... better safe than sorry when it comes to the fluid that keeps your bearings happy. Stay on top of it
Old Jun 25, 2008 | 07:21 AM
Bluovlh8er's Avatar
i just unpluged mine
Old Jun 25, 2008 | 01:16 PM
96 Z 28's Avatar
Yup Me too
Just make sure to check the fluid every once in a while
Old Jun 25, 2008 | 01:22 PM
buy another sensor you cheap bastards when your 15 yr old radiator hose(s) spring a leak and you never know it until your motor seizes up.... well, nevermind, mechanics need work too. seriously though, it's a gauge i want to have on mine.
Old Jun 25, 2008 | 02:06 PM
Skywise's Avatar
That's not funny man! (Oh yeah... I can smile about it NOW)
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
