Exhaust rattle
Exhaust rattle
I have a Magnaflow catback that has been on the car for about 2 months. When it gets hot, it seems to cause a rattle. Anyone with fitment tricks? My guess is that it is hitting the driveshaft. i have tried to adjust it, but no matter what I do, I cannot get it to clear enough.
Thanks
Thanks
Have you checked to see if its hitting the sheetmetal "g-load" brace that connects the right and left floorpans, right under the intermediate pipe? That's a common place for exhaust sytem interference.
It does hit there if I rotate it off the driveshaft. It only appears to be hitting the lower half of it. Can I cut it down here, or is important for structure / strength?
What can "safely" be used to wedge into this area? I am pretty sure its the over the axle portion of the I pipe thats hitting. I read tons of posts. Some have used radiator hose, muffler tape rolled up....What would work best?
Update:
I installed three washers on each side of the brace in the center of the car. No more rubbing, and the car is a lot smoother now. I did not realize how much vibration I was picking up from this. I assumed it was the driveshaft, but not any more!
thanks for the help all
jim
jim
Update:
jim
jim
May 15, 2015 10:43 AM
squarehead
Nov 21, 2014 08:02 PM
