Can anyone identify this valve spring?
Old May 24, 2008 | 10:05 AM
user 647483's Avatar
I managed to break one because someone didn't install the heads properly.
For some reason I was sure they were 977s, but they don't look like the 977s on Summit's page.
They look more like the 924s. Or even Crane 96849s or Crane 96848s
They were on the LE2 heads when I bought them (sold as "unused", but certainly not the original springs)
And no, it is not bent or smashed. I used the scanner to get the pic since my camera can't focus on
something that small and get any detail.
Old May 24, 2008 | 08:50 PM
1989TransAm's Avatar
Sometime those photos are only representive of the part and not the actual photo. Not sure if that was the case in your situation.
Old May 25, 2008 | 12:22 AM
TeamingTealZ28's Avatar
Kind of hard to indentify.
But my vote goes to the Comp #987's
Old May 25, 2008 | 12:24 AM
But dont go by the pics on summit, they arent correct.
They look like my 987s i had. with the flat inner spring
Old May 25, 2008 | 01:35 AM
COMP CAM 918's!!!
DEFINITLY!!
Old May 25, 2008 | 01:50 AM
AdioSS's Avatar
West South Central Moderator
Originally Posted by TeamingTealZ28
COMP CAM 918's!!!
DEFINITLY!!
the 26918s are single wire beehives...
measure the inside and outside diameters of both springs. Take it to a shop that can measure the spring rate.
Old May 25, 2008 | 02:39 PM
96capricemgr's Avatar
How were they mis-installed?
Old May 25, 2008 | 02:57 PM
The springs were properly installed, the head bolts were what was not installed properly.
One of the head bolts was torqued down over the shims, breaking them.
That caused the springs to sit funny and ultimately caused two to fail. (one inner, one outer)
We combined the two broken ones to make one good one.
They all tested good with a pressure tester.
I had the heads refreshed, new K800 springs and TrickFlow guideplates installed.
Fortunately, the valves were still in great shape.
Old May 25, 2008 | 11:50 PM
MachinistOne's Avatar
Do you have any idea just how many valve springs look just like that one - there is no way you are going to accurately identify a spring by how it looks.
Old May 26, 2008 | 12:00 AM
I was worried you were going to say that.
Old May 29, 2008 | 07:18 PM
wrd1972's Avatar
COMP CAM 918's!!!
DEFINITLY!!
Uh no.
Old May 29, 2008 | 07:21 PM
Confirmed, they are in fact 977s.
http://www.jegs.com/i/Comp+Cams/249/977-16/10002/-1
http://www.sdparts.com/product/CC977...lveSpring.aspx
Jegs, a few other sites and Lloyd agree.
(Actually, now that I look back on my emails, he did say that they were 977s when he removed and tested them for me)
Thanks guys.
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
