who for a tranny rebuild?
Old May 15, 2008 | 07:38 PM
cals400ex's Avatar
i am looking for a tranny rebuild on my 2000 Z28. i am down between CPT and FLT. i didn't know the differences between the 2 companies and which parts they use. both have an excellent reputation. i know CPT has a good reputation here and FLT has a good reputation on other sites. i don't want any ripping on one company. i just want to do some comparing and contrasting. any help would be great.
Old May 15, 2008 | 08:10 PM
IROCThisZ28ForLife's Avatar
well the best way to do that would be to call up each one and see who fits your bill better. I personally am going with CPT cause he offers great advice and always answers my idiodic questions =)
Old May 15, 2008 | 08:34 PM
12SCNDZ's Avatar
Can I give my vote???...LOL Seriously, we love people to check our reputation, but check price compared to that reputation. I won't take anything away from FLT. From what I know, they build a good unit. I will say this much, though, it's comforting to see you've narrowed it down to the 2 of us. You've obviously been doing some research. Remember, a big price tag doesn't always buy the best transmissions.
Here's a run down of the parts we use. There's a few things that need to be updated here. All of our "Pro Race" units now get brand new GM 5 pinion front planetaries, and we now use .500" boost valves in the "Race" and "Pro Race" units.
http://www.geocities.com/cahallperfo...l60ebuild.html
Frank
CPT
302-250-1202
Old May 16, 2008 | 02:38 AM
cals400ex's Avatar
i am not sure what the boost valves are? are your trannys setup like stock or do they use the vacuum modulator kits? it appears a lot of the parts you and FLT use are the same. yes, there are some differences. why do you not use the trans go shift kits? i was under the impression that they helped the transmission live a little longer. so i guess i can't just order a tranny from you before i ship mine in? i was hoping to have less down time by doing this. with how you charge for the hard parts, i wasn't sure if this was possible. if i can order one straight up from you, how long would it take? thanks
here is a list of items in the FLT trannys. you can get the output shaft as an added option too:
FLT performance built pump ( Includes machined pump halfs to ensure flat surfaces, New delco 13 vain pump/rotor/slide kit )
FLT sleeved input drum
FLT beast shell kit w/bearing
GM 5 pinion input carrier
GM 5 pinion reaction carrier
Bearing style reaction shaft
New reverse input drum
Alto wide 2-4 carbon lined band with reinforced anchor
8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Sonnax super hold 4th servo
Bushing kit
New solenoids
New Internal wire harness ( If needed on 4L70E )
New GM Spacer plate
B/W clutches
Seal & gasket kit
Filter with fiber pan gasket
Updated aluminum accumulator pistons
FLT prepped valvebody
Set end play to FLT specs
Old May 16, 2008 | 06:08 AM
12SCNDZ's Avatar
If you know what you're doing, you don't need a "shift kit" in a transmission. We make our own modifications to control shift feel. Ask any of our customers how their transmissions shift.
We use the MUCH siperior billet 2nd gear servo. It helps both the 1-2 and 2-3 shift, as well as prevents the "bang the rev limiter" on the 2-3 shift.
You can't use a "sleeved" input drum in a 4L60E. If you do, you can't use the steel input piston set. We've seen WAY more aluminum forward pistons break, than you'll ever see drums break.
A 13 Vane rotor kit won't do anything unless it's installed in a REAL 13 vane pump. The feed slots are machined different in a real 13 vane pump, so there's absolutely no benefit to switching to a 13 vane rotor in a 10 vane pump. It's counter productive to add a 13 vane rotor, especially when it does no good, because we've seen more 13 vane rotors fail.
We NEVER use vacuum modulators in a 4L60E. They're a perfect way to ruin a good transmission. I've wrote about this subject several times on this board.
Frank
CPT
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
